Thread: turn signal problem?
10-25-2010, 08:38 AM #1
So i noticed my right front turn signal was out so i went to change the bulb and notice the bulb had blown and the connector appeared to be kind of black and the grease looked to be fried a bit. i went a head and changed the bulb and it worked when i tested it but went out as soon as i put everything back together
so my question is do i need to replace the connector or is their maybe just a bad connection due to the fried bulb grease and if so can i just clean the connector with some brake cleaner or something?
10-25-2010, 09:36 AM #2
- Feb 2008
- san jose ca
navy blue metallic- 2001 z28
The same think happened to mine..I had the clear signals and water was getting to the connector.I put a dap of rtv around the connector to seal it to the housing of the light. Hasn't went out since (blew out twice before using rtv)
10-25-2010, 09:51 AM #3
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
if the socket is in bad enough shape, you need to change it. im pretty sure they're the same as firebirds, and you can get them at the parts store for about $6. inspect your housing very well also, because there is probably water getting in somewhere.
10-25-2010, 11:45 AM #4
If I can get the socket for $8 I'll probably just change it. Is it hard to change the socket?
10-25-2010, 12:19 PM #5
- Oct 2007
- Muncie, IN
nope, cut 3 wires then splice new ones in . . . make sure to you leave yourself plenty of slack
10-25-2010, 02:34 PM #6
ok i just checked my bulb before i bought a new socket and when i turn my lights on the bulb lights up but when i turn my signal on it doesn't blink it just stays lit. still a socket problem or something else?
also i just checked my hazards and they all flash but the passenger front. possible flasher problem?Last edited by DMAN; 10-25-2010 at 02:45 PM.
10-25-2010, 04:21 PM #7
fixed it! it was the flasher.
turn signal problem
By Firebirdformula in forum Firebird / WS6Replies: 7Last Post: 06-07-2010, 04:55 PM -
Turn Signal problem
By Camaroride32 in forum General HelpReplies: 3Last Post: 04-16-2008, 03:23 PM -
Left Turn Signal Problem
By 6speedTAthistime in forum Firebird / WS6Replies: 6Last Post: 11-21-2007, 06:53 PM -
Turn signal problem
By {FzS}BlacKMagicK in forum General HelpReplies: 10Last Post: 05-01-2007, 05:27 AM -
Turn Signal Problem
By M.RedWS6 in forum Firebird / WS6Replies: 5Last Post: 11-25-2006, 10:02 AM
