Thread: Diablo tune or ????????
04-12-2008, 10:24 PM #1Junior Member
- Dec 2006
- Connecticut
yellow- 2004 gto
I have a stock gto with a cai and a variam with a maf ports, I have a diablo tune witch I ran a 13.3 in the 1/4 on street tires. I found a tune on this site and found it wasn't better than the diablo tune. any help? I don't want to damage the engine, any experts out there? don't known what is correct. Any help would be great, Thanks Ron
04-14-2008, 07:57 AM #2
Yeah you need to drive on the freeway for a 10-15 mile drive cycle with the cruise on @ at least 2000 rpm and then monitor/log your LT Fuel Trims. You want to be in the area of 1- -1. Look at that data and post your results. Remember the throttle has to be steady as in NO changes thats why it's best to have the cruise on.
04-14-2008, 06:02 PM #3Junior Member
- Dec 2006
- Connecticut
yellow- 2004 gto
Thanks for the info, but I have trouble still. I will try what you said but know I have a trouble with a trouble code. I just added the ports to the maf, and the vairam to the throdle body. I di put nascar tune in and it didn't seem to be any better, as I said before, so I have the diablo tune in now and I have to say the car does run good. I found that I had a trouble code for ( bank 1, two lean.) so I cleared it and and drove around 12 miles with the cruise on and set for 60. to see if the mpg was still good, witch at 60 I was avg. around 28. not bad. so I'm looking for help with this code, should I take the ports out? or the vairam?, will this hurt the engine? and also with both tunes my long term showed around 15.4 to 17.4. where do you get a crash course on tunes? Thanks for the help Ron
04-20-2008, 08:45 PM #4Info By 06MonteSSk, if positive ltfts - yes you're lean... so you adjust your slope negative to richen that up... changing the injector slope changes how much fuel is sprayed - in BOTH normal driving AND PE/WOT... now, it says to lean out the PE fuel tables by the same amount - because you just richened it up by adjusting your injector slope.
PE/WOT fueling adjustment works the OPPOSITE of the injector slope adjustments....
for injector slope - going negative (left) makes you richer. going positive (right) makes you leaner.
for PE/WOT fueling - going negative (left) makes you leaner (taking away fuel from WOT). going positive (right) makes you richer (adding fuel to WOT).
THis was a question I had a day or so ago, & I'd thought I'd pass it to you.......I hope Monte didn't mind.
Your LTFTs seem alot like mine, almost the same. I went to injector slope & went -14, & did the like -12 on the fuel lean & it dialed my LTFTs right in.
Plus, I disabled my rear O2s for LTs, if ya have em.
good luck-----------------------------------
2004 Silver GTO
K&N CAI
ported MAF housing
SLP 1 3/4" LT coated headers
SLP LM exhaust
High Flow cats
B&M ripper
DiabloSport Predator Tuned
....so much more to go. $ = hp
Diablo Tune for 04 GTO
By surfinjoe in forum GTOReplies: 4Last Post: 06-08-2010, 03:58 AM -
Question: Diablo Tune LOOK PLEASE!!
By pmolina0436 in forum GTOReplies: 26Last Post: 09-17-2008, 07:49 PM -
Help: Diablo Tune
By pmolina0436 in forum GTOReplies: 4Last Post: 08-27-2008, 05:04 AM -
diablo tune
By kebie05 in forum Computer & TuningReplies: 8Last Post: 10-14-2007, 09:47 AM -
Diablo Tune
By AFASTYZFR1 in forum Computer & TuningReplies: 3Last Post: 12-11-2006, 02:19 PM
