Results 1 to 10 of 10
    Member 01ssSLP's Avatar
    Lancaster, PA
    01 camaro ss
    o2 sensor problem
    Hello to all! Ok my problem starts with my o2 sensor bank 2 sensor 1. (The one upstream on the passager side.) I put a new one on had the SES light turned out drove it for 30 miles and it came back on. It is stock cats with a flowmaster cat back, so im not sure whats going on here. Now i do have apair of LT's with high flow cats i just order sitting here. By putting them on would this help at all? The car will not pass state emissions because of this problem. (The SES light) Any help would be great! Thank you.
    Junior Member extanker's Avatar
    Jun 2006
    trenton nj
    07 z06
    what codes are ya showing ?
    Lancaster, PA
    01 camaro ss
    Not sure on the code so ill have to get back to you on that one.
    Lancaster, PA
    01 camaro ss
    The code that is showing is p0154. Is this up or downstream driver or passager side?
    Senior Member
    Jacksonville, FL
    P0154 is insufficient activity bank 2, sensor 1 (passenger side, precat). Assuming the sensor is OK something else is going on - loose sensor, wiring, corroded connector, etc. www.gearchatter.com/viewtopic9159.php
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    SameO
    I had the same code after header install and could not get rid of it. Turned out to be a small exhaust leak aft of #2 O2 on passenger side. I didn't think it would effect the front O2 but must have. After fixing leak light has stayed out. Good luck
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    Lancaster, PA
    01 camaro ss
    Thanks to all for the help! Going into to garage tomorrow to see whats up. I will post to let you know whats going on.
    Lancaster, PA
    01 camaro ss
    just wanted to up everyone. Im getting my car back but they still arent 100% on what it is. Has something to do with the drive cycle and the monitors not comeing in.
    Senior Member
    Jacksonville, FL
    Some info on drivecycle/readiness monitors: www.obdii.com/drivecycle.html
    Lancaster, PA
    01 camaro ss
    Just wantedto let everyone know problem is fixed! There was a tear in the o2 sensor sleeve up by the computer. Cost was 75 bucks. Never would have that of that. Thanks again for everyones help!!!
  1. Help: Acceleration problem!!! o2 sensor?
    By UC Warrior 1 in forum General Help
    Last Post: 07-07-2013, 04:01 PM
  2. Question: Yet another problem.. Knock sensor
    By flybird in forum V6
    Last Post: 01-10-2012, 04:36 AM
  3. Help: Crazy Sensor Problem!!! :help:
    By skinypuppy in forum External Engine
    Last Post: 07-23-2011, 12:20 PM
  4. O2 sensor problem
    By homer311 in forum External Engine
    Last Post: 08-18-2006, 12:11 PM
  5. Sensor Problem
    By HighBallLS1 in forum General Help
    Last Post: 10-29-2005, 08:14 AM
