Thread: O2 sensor problem
08-14-2006, 02:39 PM #1Junior Member
- Jul 2006
- California
Black- 2002 Trans Am
O2 sensor problem
Just a quick question. Over the past 2 weeks i have had the service engine light come on with the Code P0135 3 times. The booklet says it is an O2 sensor heater circuit malfunction. Bank 1 sensor 1. I was just wondering as to the degree of concern i should have with this problem and what i could do to fix it.
Thanks
08-14-2006, 02:53 PM #2Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
fueling will be off, throttle response will be an issue. check the wires and make sure they arent burnt. you may also need to replace the sensor.
08-14-2006, 05:24 PM #3Junior Member
- Jul 2006
- California
ok. i was expecting the possibility of replacing the sensor. If i replace the one that is malfunctioning, would i have to replace the other one as well?
08-14-2006, 06:01 PM #4
No, Just replace the one thats giving you issues.
08-14-2006, 10:15 PM #5
Do you have LT's? That's a common code with headers. Might want to look at Bosch 13111's. They are supposed to help this problem.
08-15-2006, 04:41 AM #6Senior Member
- Aug 2003
- Honolulu HI
supposed to, but dont always do it.
08-15-2006, 09:20 AM #7Junior Member
- Jul 2006
- California
Nope no LTs. I live in california so long tubes are pretty much not an option for my car. But i have heard good things about bosch products. Have to check them out
08-18-2006, 12:11 PM #8Junior Member
- Feb 2006
- LAKE GENEVA WI
YELLOW- 1970 VW BEETLE
i've gone through three upstream bosche o2's in the past couple weeks. so i'd stay away. i'm going to try delphi one's.
Help: Acceleration problem!!! o2 sensor?
By UC Warrior 1 in forum General HelpReplies: 46Last Post: 07-07-2013, 04:01 PM -
Question: Yet another problem.. Knock sensor
By flybird in forum V6Replies: 35Last Post: 01-10-2012, 04:36 AM -
Help: Crazy Sensor Problem!!! :help:
By skinypuppy in forum External EngineReplies: 5Last Post: 07-23-2011, 12:20 PM -
Help: o2 sensor problem
By 01ssSLP in forum General HelpReplies: 9Last Post: 04-24-2008, 07:54 AM -
Sensor Problem
By HighBallLS1 in forum General HelpReplies: 4Last Post: 10-29-2005, 08:14 AM
