Results 1 to 16 of 16
04-11-2008, 01:28 PM #1Member
- Jan 2006
- Memphis,TN
Black- 2001 Z28 Camaro
Popping noise coming from front of car
I get this popping noise from the front of my car when going over bumps in the road and sometimes when turning. I think it might be suspension related but i'm not sure
Any ideas on what it could be and around how much am I looking to spend if something has to be replaced?
04-11-2008, 07:16 PM #2Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
probably shocks, control arm, try asking in suspension.
04-11-2008, 07:56 PM #3Member
- Jan 2006
- Memphis,TN
hmm alright, can a Mod move this to the suspension thread plz?
04-13-2008, 04:33 PM #4
I also am getting this popping noise from the front wheel area especially when turning. Could this be a bad ball joint or perhaps tie rod?
04-13-2008, 04:46 PM #5Impounded
- Oct 2007
- Beaver Dam KY
Inspect the outer tie rod ends. I changed both of mine and i still have the pop. Ive heard it was a special bearing in the steering shaft.. thread by me somewhere. All 4 balljoints/bushings replaced soon.
04-13-2008, 05:21 PM #6
I checked them and Im pretty sure theyre ok. But when it popped 2 days ago my steering wheel turned so its not centered any more. I did an alignment and made sure everythng was tight before that pop happened. IM hoping nothing is wrong with the rack itself. I have an idea that my problem could be the bolts on the bottom of the control arm could be messed up. Could that cause the steering wheel to shift?
04-13-2008, 06:33 PM #7
if the adjustment bolts came loose, the lower control arm would move and cause the steering wheel to change position.
04-13-2008, 06:50 PM #8
Ok i think thats what happened. Do u know what they should be torqued to? And if i needed new bolts how much those cost?
04-13-2008, 06:52 PM #9
i just make them really tight. if they did move, you will need to have an alignment done anyway. you won't need new bolts.
04-13-2008, 07:05 PM #10
Ok im doin my alignment tomorrow and once again ill make sure they are very tight. When i get home ill make sure it didnt move and ill tell ya if it was just the bolts
04-14-2008, 05:16 AM #11Member
- Jan 2006
- Memphis,TN
I recently I had an alignment done and I still had the popping noise afterwards...weird thing is though that when I was on my way home a few days ago I hit a bump in the road at a pretty good speed and haven't heard the popping since.
04-14-2008, 10:28 AM #12
I had the bracket for the front sway bar break and it made a popping noise as well.
04-14-2008, 11:11 AM #13Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Stabalizer End Links
04-14-2008, 11:24 AM #14
the driver's side sway bar bracket is prone to breaking as well. i've seen it.
04-17-2008, 06:29 PM #15
ok got my alignment done and one of the bolts on my control arm has a pin to lock it and this pin was not in the hole so the bolt kept coming loose. So far no problems thanks for the help
04-17-2008, 08:51 PM #16Impounded
- Oct 2007
- Beaver Dam KY
Im checking out mine tomorrow.
Help: Popping coming from the front driver side while braking!!!!!
By corvixcanto in forum General HelpReplies: 7Last Post: 08-09-2012, 02:01 PM -
Popping noise coming from suspension
By iceman504 in forum Suspension and HandlingReplies: 4Last Post: 11-05-2010, 08:26 AM -
front suspension popping noise
By godless-phoenix in forum Suspension and HandlingReplies: 21Last Post: 03-30-2010, 11:20 PM -
Help: Still a popping noise!
By JoshieDoom in forum General HelpReplies: 11Last Post: 04-03-2008, 09:07 PM -
hmm...popping noise?
By blackhawk01 in forum DrivetrainReplies: 13Last Post: 11-20-2007, 08:08 PM
