    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Still a popping noise!
    So i changed both my tie rod ends and im still having a popping noise when turning under 10mph or braking under 10mph.. Im beggining to believe that im going to have to replace all 4 balljoints...
    Ideas??
    doylestown, Pa
    SILVER
    2004 CTS-V
    I would take it to a shop and have them check it out unless you are capable of jacking it up and checking it yourself.
    Beaver Dam KY
    79 T/A -91 Firebird
    Yeah I did the tie rod ends and measured everything up correctly. Ive checked everything. I hope that it isnt the tie rod themselfs going out...
    My Neighbors Hate Me!!! lvbroham1's Avatar
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    2001 Chevy Camaro SS
    Had this same problem in my Camaro. It's not the ball joints its a special seal in the steering shaft. If i'm not mistaken the parts only like $30 but the labor is insane on the fix. I'll look and try to come up with a part # asap.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Take it somewhere and have them check the balljoints, you don't want to have one break on you.
    Beaver Dam KY
    79 T/A -91 Firebird
    lvbroham1, give me all the info on it when you get the chance. Ive checked the ball joints and there is no play. Everything looks good. Im going to take apart everything this weekend and paint the caliper brackets and calipers and do some cleaning. Ill look for that "special seal"
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    alright, I looked and found the part # the guy gave me. it's the bearing kit for the shaft. The gm part # is 26032824. Hope this helps. The guy told me old chevy 4x4 trucks have the same problem, but most people don't fix it, they just live with it cause of the price of labor. It won't mess up anything if your alignment and everything else is ok.
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    P.S. if you look up the part # on gmpartsdirect it will show you the location of those bearings.
    rsg98Z28 rsg98Z28's Avatar
    Atlanta, GA
    1998 Camaro Z28 vert
    My car does that same thing for now if just been living with it but everytime i hear it it makes me nervous
    Beaver Dam KY
    79 T/A -91 Firebird
    Looked up the part number and no location was shown..
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    I think you might have to search for it in their parts catalog. Just put in year make and model then click on steering gear and linkage, then bearing assembly. I should say next to it view illustration. Click on that. It will show you a lay out of where it's located at and what parts are around it.
    Beaver Dam KY
    79 T/A -91 Firebird
    ahh. I see it now. It doesnt look that bad. If im going to replace it im gonna wait till I get a tubular k member and new engine/tranny.
  1. Popping noise coming from front of car
    By iceman504 in forum Suspension and Handling
    Last Post: 04-17-2008, 08:51 PM
  2. Wierd popping noise
    By JoshieDoom in forum Drivetrain
    Last Post: 01-31-2008, 09:12 PM
  3. hmm...popping noise?
    By blackhawk01 in forum Drivetrain
    Last Post: 11-20-2007, 08:08 PM
  4. Popping noise?
    By Tide in forum GTO
    Last Post: 09-19-2006, 04:53 AM
  5. popping noise after installing Lt's
    By glvr01 in forum General Help
    Last Post: 04-15-2006, 03:26 AM
