Thread: Drag Bags..
04-10-2008, 08:16 PM #1I Like It Stroked
- Aug 2007
- Greeley,Co
Artic White- 1999 Z28 408 Stroker M6
Drag Bags..
Hi Guys, I just installed drag bags in my camaro and I wanted to see if running a t was ok and what lbs of air to run them at? and should I split them off the t?
04-11-2008, 05:37 AM #2
I think you are supposed to have one valve for each side. I thought they made the bags so you could adjust the pressure on the side that goes down when you launch to make it launch straighter?
04-11-2008, 06:06 AM #3
Don't t them. If your car leaves hard, you may find that having more psi in the rr will help. Every car is different. Try diff combos to see what works for you.
04-11-2008, 06:49 AM #4Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Mine is split at the t I run between 5 and 10 psi
04-11-2008, 08:17 AM #5I Like It Stroked
- Aug 2007
- Greeley,Co
I just split them up in two, so they are both independent valves. It seems like the less psi I have in them the more the car bogs...?
99 Camaro Z28-
Colorado's Slowest 408 with a 150 shot
95 Camaro Z28 LT1-
LT4 Hot Cam Kit, Fuddle 3,800 Stall
http://www.fquick.com/99Ls1fever
04-11-2008, 08:41 AM #6
How do you bog w/ what looks like a lot of power from your sig?
04-11-2008, 10:28 AM #7I Like It Stroked
- Aug 2007
- Greeley,Co
It just seems like it boggs to me
lol Im crazy lol, I just put 28psi into the right and 20psi in the left and it seems like it leaves better to me with more psi in them...
Help: Drag Bags
By RoadWrath04 in forum GTOReplies: 10Last Post: 05-26-2010, 01:34 PM -
Drag bags
By Texas Jack in forum GTOReplies: 64Last Post: 12-25-2008, 11:40 AM -
Drag Bags ?
By Mich's04 in forum GTOReplies: 5Last Post: 10-11-2007, 01:40 PM -
drag bags
By kyemt in forum GTOReplies: 1Last Post: 09-04-2007, 11:11 PM -
drag bags
By kyemt in forum GTOReplies: 6Last Post: 08-05-2007, 03:10 PM
