Results 1 to 20 of 34
    Member william SS's Avatar
    Tulsa, OK
    2001 camaro SS
    Well Ive got a 2001 ss A4 camaro. Its a weekend/strip which im just about finished with. Has 47000 miles and mods are below in random order. Any idea what ET I'll run in the quarter?
    Slp lid, slp maf, K&N, ported tb, Stb, QA1 shocks, SFC, Adj Torque Arm, LCA, Flowtech Lt/ Y-pipe, borla catback, Perfomabuilt level 2 trans, vig 3400 stall, Moser 9" with 3.89's, EPP pst driveshaft, driveshaft safety loop, professionally dyno tuned, MT Et street radials 275/60/15, Mt sportsman S/R 26x6.00 R15Lt, ud pulley, TR 224/224 114 lsa cam, AFR 205 heads, 36 lb injectors, racetronix fuel pump, NX wet kit 150 shot, and removed spare tire and jack.
    LTX N20LT4's Avatar
    Cali
    10's N/A
    I'm not sure about quarter-mile, but I would be very careful running that 150-shot on top of the mods you have with the stock bottom end. You should easily exceed 500-rear-wheel on the squeeze.
    Member RARON455's Avatar
    fort worth texas
    98 Ram air T/A Ls1/T-56
    dont know either but Definately post it when you run it.
    my stab in the dark would be probably around lowish 11s if it hooks well
    CAM mmmmmm... Toes's Avatar
    Denver CO
    WHITE
    2000 Z28 M6
    All that and you havent been to the track yet! get out there you should be running low 11's with some practice
    Member GotN2O's Avatar
    NM
    fraz fraz1le's Avatar
    London Ky
    1998 WS6
    You should def. run in the high 10's with some better tires than those sportsmans. It depends on the track alt. and how it hooks.
    NM
    Quote Originally Posted by fraz1le View Post
    I think he is running drag radials in the rear and sportsmans in the front.
    Tulsa, OK
    2001 camaro SS
    I thought the Sportmans skinnies were pretty good? The track I'm racing at is Tulsa at 620ft above sea level. Im kinda confused by what is being said. Ive got 275/60/16 MT et street radials in the rear and Sportmans skinnies up front.
    NM
    Quote Originally Posted by william SS View Post
    Thats exactly what I was saying the other guy was confused that you were running sportsmans in the rear, I am running the exact same tires front and rear as you are. Thats a great combo, those drag radials will hook like the ET streets.
    London Ky
    1998 WS6
    Sorry I scan over it a little to fast. Your car should put down good #'s with that set up.
    Tulsa, OK
    2001 camaro SS
    After doing all those mods all I really hsve left is to put it on the dyno which I will be doing in two weeks. Ill post the numbers afterwards. Then its off to the track to see what she'll do.
    NM
    good luck
    Marylandistan
    2001 Trans Am (sold)
    I'd say the 4L60 would be on borrowed time.
    Tulsa, OK
    2001 camaro SS
    Quote Originally Posted by INMY01TA View Post
    Are you talking about the stock one that I just took out or the one I just put in? The one I just put in is new and good up to 700 hp.
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    With traction and on a good day you should be in the low 11's....might be able to clip into the 10's with the 150 shot. Fortunately, you have the rear and tranny to support the mods and a 150 shot....fire away and post up once you get a chance to run it.
    Marylandistan
    Once your into the 10s none of em last no matter who built it.
    Member krug07's Avatar
    skiatook oklahoma
    pewter
    01 trans am ws6
    i say low 11's maybe high 10's. i race at the tulsa dragstrip also. Ill be out there soon after i get my nitto DR's on. it would be nice to see ya out there. i own a 01 trans am ws6 m6 pewter. Hitt me up sometime when you head out there.
    Drag racing is a disease! RacerBob's Avatar
    Feb 2008
    Youngstown, Ohio
    Maroon
    2000 Z28
    I'd guess 11.30s. Good luck! I can't wait for the times.
    Drag racing...just another numbers game.
    Vortech Super Charger, 9" w/4.11, 3200 Stall, BMR SFC, BMR TracPak, !MAF screen, 160 T-Stat.
    orlando, fl
    pewter
    00 Camaro SS SLP
    I say 11.6 to 11.40 @117-119 on the motor... 10.8-10.7 @ 128-130 on the gas.
    as long as you can cut better than 1.55 60ft time and you have good bottle pressure...900-1100lbs
    oh... BTW... make sure you air down your tires!!!
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    Have you run it yet? Not sure what the elevation is where you're running but my guess would be mid 10's if you can hook up and maybe 125-130mph.
  1. et guess/estimates please
    By Z28boy2000 in forum Drag Racing
    Last Post: 10-22-2011, 06:35 AM
  2. hp/tq estimates?
    By [email protected] in forum Firebird / WS6
    Last Post: 04-18-2010, 06:20 AM
  3. Going to get estimates today......
    By JoshieDoom in forum Firebird / WS6
    Last Post: 08-11-2008, 05:31 AM
  4. Estimates
    By jrocs00z28 in forum Corvette
    Last Post: 12-23-2007, 08:39 PM
  5. 1/4 mile estimates
    By fox87stang in forum Drag Racing
    Last Post: 10-08-2007, 06:19 PM
