Results 1 to 20 of 93
Thread: et guess/estimates please
10-06-2011, 08:46 AM #1Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
Well it's that time to head to the local track tomorrow. I would appreciate any guesses for my et.
Mods as follows
-tsp torquer 2
-fast 92/92
-98mm FTP lid
-built tranny (a4)
-4k stall
-umi tunnel mount t/a
-umi 3pt sfc's
-umi chromemoly lca's and panhard with rod ends
-LCA Relo brackets
-pacesetters headers
-cut out
-nitto nt05r's out back
-3.73's - stock 10 bolt
-comp engineering drag shocks
** first pass with the car since all mods **Last edited by Z28boy2000; 10-07-2011 at 03:45 AM.
10-06-2011, 10:49 AM #2
10-06-2011, 12:43 PM #3
No mention of any rear gear or sticky tire?
10-06-2011, 01:18 PM #4Senior Member
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
Mid to high 12's... the nt05 is a drag radial, dont know how well they hook though.
10-06-2011, 02:26 PM #5Senior Member
- Jun 2008
- 2000 Camaro B4C
Nitto NT05'r out back and 3.73's
10-06-2011, 02:35 PM #6
10-06-2011, 04:01 PM #7
I know which ones dont even with a stock converter!
hahaha I was doing some reading and I have seen where most guys say you shouldnt do a huge burn out with them. I had 555s on my 04 GTO and I just would spin to clean them off and cut a 1.905 with a 6-speed stock suspension.
Ok, we have the same car but you have REAL mods. My mods dont do shit for power and my car is hitting 13.0XX at just under 107 so I think if you hool half way you will be in the mid 12s if the DA isnt killing you.
Remember, converters do eat some MPH on the top end.
You are probably right, I am thinking best case.
10-06-2011, 04:06 PM #8
12.67
10-06-2011, 04:15 PM #9Former Mopar Man
- Jun 2011
- Branchville, NJ
12.77 if the rear holds up.
10-06-2011, 06:01 PM #10
You have a 11 second car with the mods you have mentioned. But you have two issues. The nitto's will not handle the power you have. You will need ET Streets or a slick to get your best times. That is the first issue. I would start saving for a 12 bolt or 9" now if you have not already. The stock 10 bolt will not last long behind the power you could put out. Even running just nitto's you are taking a big chance. My guess on time mid to low 12's.
10-06-2011, 06:29 PM #11
10-06-2011, 06:38 PM #12
I agree that is only a 12 second car as is, But for me most of that is based on the tire he is using. I am thinking he has headers not mentioned in the mod list. I see the cut out mentioned with headers ??
So with that he is close to my setup. 231/237 TSP,LS6 intake,Pacesetter Headers,true duals dumped at the axel,4000 TCI,3.73's. I was into the high 11's with ET Streets. I got in the Mid 11's with Hoosier Race Slicks. And it was done on a 10 bolt before it went.Last edited by Z28Thunder; 10-06-2011 at 06:46 PM.
10-06-2011, 08:14 PM #13
And now I'm on your side
I didn't make the observation of having a cut out probably means he has headers. Since he didn't have headers (in my mind), it also meant to me that he probably didn't have a cam upgrade(even though it's right there in front of me)........so, I'm going to revise again. 12.38
Thanks ZThunder!
'89 Turbo Trans Am Pace Car (Mom's car now)
'68 Camaro - 572 coming soon
'67 Nova - 406 SBC, PG
'10 ZR1
10-06-2011, 08:46 PM #14
10-06-2011, 08:53 PM #15Senior Member
- Jun 2008
- 2000 Camaro B4C
As far as hp goes when I did the cam swap I had it dyno'd after the tune. I had a stock ls1 intake and tb and made 371. With the new fast and a new tune my tuner says I should be damn close to 400...just havent had time on a dyno yet.
And to edit my original post **I have pacesetter headers and a cutout**
10-06-2011, 09:02 PM #16
decent 60' will put you in the 11's IMO......I'm gonna say 11.80's. That car definitely has 11's in it with traction. More stall, more cam, and more intake/tb than I got and my car went 11.80's on high 1.60's 60'.
10-06-2011, 09:17 PM #17
10-06-2011, 09:18 PM #18
10-06-2011, 09:39 PM #19
Well to be fair here...he asked what his "current set-up" will run. Tires, bigger stall, bigger cam, etc is just all speculation because he doesn't have any of that.
I also don't see relocation brackets for the LCA's as a mod.
He is going to have major traction issues and a weak 60' time.
My time above stands
I might be on the high side a little though.
10-06-2011, 09:52 PM #20
Dyno Estimates
By Z28boy2000 in forum External EngineReplies: 9Last Post: 05-17-2010, 09:04 PM -
hp/tq estimates?
By [email protected] in forum Firebird / WS6Replies: 5Last Post: 04-18-2010, 06:20 AM -
Estimates
By jrocs00z28 in forum CorvetteReplies: 2Last Post: 12-23-2007, 08:39 PM -
1/4 mile estimates
By fox87stang in forum Drag RacingReplies: 16Last Post: 10-08-2007, 06:19 PM
The nitto's will not net the best ET period. To me it is all in the 60' and he has all the right things for a good 60' minus the tires. Well that and a stock 10 bolt..
