Thread: Threw a Code
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    Threw a Code
    Threw a code it was something like 02 heater malfunction... soo what does this mean?? i got long tubes with no cat... anything i have to do... oh ya it was bank 1
    Bragg NC
    Met. Sunset Orange
    01 SS
    Post up the code so we can hook you up with some info.
    J
    Puyallup
    deleted the code i will see if it will throw it again..
    heater codes are pretty common with LT's. I'm switching to bosch 13111 sensors this summer when I go back to closed loop to see how those do. I've read mixed reviews on that helping the problem. Firebirdjones also switched over so we're going to see between the both of us how they work.
    LT1 Guy
    Va Beach
    Quicksilver
    03 Corvette Z06
    Have you looked at the wireing to the sensor? I know on an LTX car if you burn the pink supply wire the o2 heater will not work. It usually kills the MAF to though. Just a thought.
    Puyallup
    wires are good and they have heat wrap on them 2
    LT1 Guy
    Va Beach
    Quicksilver
    03 Corvette Z06
    I dont know then. It might just be a faulty o2. Check the voltage across the 2 white/white and grey wires at the o2 connection. You should have 12 volts. If you dont, there is a short some were. If you do, then its probably the o2 sensor itself that bad. Thats all I can think of right now. If I come up with anything else I will post back up.
  1. Question: I threw a code....
    By transamgirl89 in forum General Help
    Last Post: 07-29-2011, 09:54 PM
  2. Threw a code???
    By hm3tocapt in forum Computer & Tuning
    Last Post: 09-30-2009, 08:30 AM
  3. Threw a Code?? (help)
    By Raoul-Duke in forum Computer & Tuning
    Last Post: 08-19-2008, 10:46 PM
  4. Threw a code
    By ledesma54 in forum Computer & Tuning
    Last Post: 07-18-2008, 11:18 AM
  5. Threw a code
    By uLs1a in forum Drivetrain
    Last Post: 09-17-2006, 03:13 PM
