Results 1 to 10 of 10
    Member TedsB4Csled's Avatar
    Feb 2008
    Asheville, NC
    2002 B4C
    Thumbs up NEW Throttle Body Bypass
    For those of you who don't want to use the old TB bypass because your up north; I got something that will work for you! Get a 1/4" ball valve with two 5/16" adapters and two hose clamps. Now cut only one of the hoses on the TB, preferably the one sending flow in, but it doesn't matter. Place the ball valve in between and open to allow coolant to flow through TB. Close it to return to stock flow. Easy and you can switch back to flow open! I have pics here;
    http://www.ashevillecamaroclub.hostsnake.com/sale.html
    If you can't find them at Home Depot I will send one to you for price on the link. Also have TB After Cooler (TBAC) that I'm testing now. That's how I came up with this new trick. Now everyone can get that extra HP for under 20 bucks!
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    Quote Originally Posted by TedsB4Csled View Post
    EXCELLENT THREAD! I'm sure this will help out a lot of people, myself included. I've always wanted to make use of the TB bypass free mod, but live in Indiana so have been reluctant to do so with frequent cold temps here.
    Feb 2008
    Asheville, NC
    2002 B4C
    My only concern is the return feed. It gets blocked by the valve when it is off. But I see no purpose for it other than sending coolant through TB. Anyone have any info on this?
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    Hmm...good question-sorry, I don't have the answer but hopefully someone does & will post it.
    Feb 2006
    2002 WS6
    well, one solution could be to drop in a t-fitting and another valve after that to get better flow control.
    Feb 2008
    Asheville, NC
    2002 B4C
    Good idea! Put a t-fitting on it....problem solved
    Jan 2008
    Fl
    Red / Lemans Blue
    00 Z28/04 Z06
    Nice idea
    Feb 2008
    Asheville, NC
    2002 B4C
    Hmmmm....would you need 2 t-fittings? One for the exit flow? Me thinks yes. Still it will be good to go!
    I flame retards CamaroFan71's Avatar
    Aug 2006
    Baton Rouge, La.
    QuickSilverMetallic
    2005 GTO M6
    And when youre done it will look like Mario and Luigi have been doing some plumbing under your hood!!! Very Cool
    Feb 2008
    Asheville, NC
    2002 B4C
    yup. hehehehe
  1. throttle body bypass on lt1
    By jimmybling31 in forum External Engine
    Last Post: 03-18-2008, 05:28 PM
  2. Throttle Body Bypass?
    By Demon_Z28 in forum External Engine
    Last Post: 03-10-2008, 03:42 PM
  3. Throttle body bypass?
    By 97ramair in forum External Engine
    Last Post: 12-05-2007, 10:44 AM
  4. throttle body bypass............
    By clg82 in forum Firebird / WS6
    Last Post: 04-29-2007, 12:54 PM
  5. Throttle body Bypass kit ? 6-8hp?
    By jinxeng in forum External Engine
    Last Post: 09-18-2006, 08:37 AM
