Results 1 to 14 of 14
Thread: Throttle body bypass?
12-02-2007, 04:53 PM #1Junior Member
- Oct 2007
- NY
Black- 97 firebird WS6
Is it really worth doing a throttle body bypass? What's the advantage? performance gains?
12-02-2007, 04:57 PM #2Impounded
- Oct 2007
- in a house
it really only benifits you at temp, id say 2-5hp at temp, its worthwhile, i did it.
12-02-2007, 05:29 PM #3
I did it as well. Can't feel anything performance wise except the throttle body staying cooler.
2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
12-03-2007, 01:57 PM #4Member
- Oct 2006
- Florida
Navy Blue Metallic- 2002 Trans Am WS6
Did mine too. Cheap and easy hp. Just not the seat in the pants kind, but every little bit helps.
12-03-2007, 08:59 PM #5Junior Member
- Jul 2006
- bay area
White- 2002 Trans Am
its free or maybe $5 bucks and itll clean up your engine bay
12-04-2007, 04:30 AM #6
Dyno testing shows about a 5HP gain across the powerband (at operating temp) on an LT1. I'd expect similar results from the LS1...
2002 WS6 Trans Am, A4, SLP lid, P&P TB, 3500 stall, 24K GVW tranny cooler, HPTuners, Pacesetter LTs, Bassani dual exhaust with 'x' crossover, coolant bypass, sealed airbox to hood.
http://www.cardomain.com/id/jag42420
12-04-2007, 05:33 PM #7Junior Member
- Oct 2007
- NY
Thanks! by the way what size headers r u using? Did u also purchase the o2 extensions? I a few weeks away from puirchasing ceramic coated pacesetters. My mechanic frinds tell me to go with 1 5/8". I think most people in this forum r using 1 3/4"
12-04-2007, 07:09 PM #8
Pacesetter long tubes only come in 1 3/4". Mid tubes are 1 5/8". Here's their website: http://www.pacesetterexhaust.com/camaro.php
12-04-2007, 09:18 PM #9
12-05-2007, 10:16 AM #102002 Z28 M6, Suncoast Creations ram air, port/polish TB w/ bypass and bumpstop, heater hose mod, stainless steel long tubes, ORY w/ dual cutouts, Magnaflow, BMR SFC, UMI Torque Arm, LS7 clutch w/ drill mod, Pro 5.0 w/ Lous short stick, MSD wires, 4.10s, good maintenancehttp://www.fquick.com/blue02z
12-05-2007, 10:23 AM #11Junior Member
- Jul 2006
- bay area
from haing hoses all over the place. all depends on what other wires and the such you might have
12-05-2007, 10:35 AM #12Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
It is cheap and easy, plan on doing mine this week, after all every little bit helps. Especially, if you can add alot of little bits
12-05-2007, 10:38 AM #13
okay, i get ya. i just know when i did mine personally i did not think it looked any better.
12-05-2007, 10:44 AM #14Junior Member
- Jul 2006
- bay area
i guess a matter of preference =)
http://www.ls1.com/forums/showthread.php?t=70855
NEW Throttle Body Bypass
By TedsB4Csled in forum General HelpReplies: 9Last Post: 04-02-2008, 06:00 AM -
throttle body bypass on lt1
By jimmybling31 in forum External EngineReplies: 6Last Post: 03-18-2008, 05:28 PM -
Throttle Body Bypass?
By Demon_Z28 in forum External EngineReplies: 5Last Post: 03-10-2008, 03:42 PM -
throttle body bypass............
By clg82 in forum Firebird / WS6Replies: 3Last Post: 04-29-2007, 12:54 PM -
Throttle body Bypass kit ? 6-8hp?
By jinxeng in forum External EngineReplies: 17Last Post: 09-18-2006, 08:37 AM
