Thread: ls1 bearings
    Missouri
    ls1 bearings
    Went to order new rod and main bearings for my '97 ls1. Parts counter guy looked surprised and said they were the same part # as older GM 350's. Does it sound to you guys like I'm getting the right parts?
    Member C&Cbird's Avatar
    Oklahoma City, Oklahoma
    Yeah, thats the only part that the two engines can swap. Actually, I'm not sure about the main bearing parts, but I know for sure on the rod bearings.
    Missouri
    Thanks!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    rod bearings are the same. here are the part numbers you will need
    CB663 rod bearings
    MS2199 main bearings
    Tulsa, ok
    i think rod bearings are the same for LS1s even. not 100% sure, though.
  1. 06' Ls2 #6 rod bearings?
    By importhater81 in forum LS2/LS3/LS4/LSx
    Last Post: 01-02-2012, 07:07 PM
  2. Cam Bearings
    By jetaws6 in forum Internal Engine
    Last Post: 08-10-2010, 04:21 AM
  3. Cam bearings
    By Z28_Driver in forum Classic Muscle
    Last Post: 11-26-2009, 02:16 PM
  4. Cam Bearings
    By slacker4321 in forum Internal Engine
    Last Post: 01-14-2009, 11:25 AM
  5. Do I need new cam bearings?
    By phoenix1987 in forum Internal Engine
    Last Post: 08-24-2006, 02:20 PM
