Thread: Cam bearings
11-18-2009, 10:50 AM #1
Cam bearings
I have to put new piston rings in an old engine. 1967 400 Pontiac with about 100,000 miles on the clock. The engine is very clean inside, however has a broken ring. I know I need these parts:
piston rings
gasket set
main bearings
rod bearings
timing gear and chain
oil pump
fuel pump (broke it pulling the engine)
Top-end is all clean and lifters and cam look perfect.
Probably will re-use stock pistons after cleaning.
Should cam bearings be replaced? Is this possible to do at home. How much should the work cost, if I cannot do it?
I have had this car sitting for about 4 years now and would like to get it back on the road in the spring. As always, I am on a budget. If I need to pay for some work to be done, I can live with that.
Thanks for any help guys.
11-18-2009, 11:47 AM #2Alabama Member
- Jan 2008
- heart of dixie
06 Jeep Grand Cherokee.- 02 superchipsZ28 M6(sold)
yes you can do it ! i always do its just better peace of mind and doesnt take long to do. you'll need a cam bearing tool which can remove and install them(parts store) with a hammer. just line up your oil holes on the new bearings and drive em in, they are beveled be sure you turn them in or out however the olds are when they come out. not sure what a machine shop would charge always done them ourselves.
11-19-2009, 07:15 PM #3
Thats what I wanted to hear. It takes all the fun out of it when I have to haul my project to the mechanic.
Do you have a preferred brand for bearings? or rings?
Thanks for the help.
11-20-2009, 05:13 AM #4
11-26-2009, 02:16 PM #5
06' Ls2 #6 rod bearings?
By importhater81 in forum LS2/LS3/LS4/LSxReplies: 10Last Post: 01-02-2012, 07:07 PM -
Cam Bearings
By jetaws6 in forum Internal EngineReplies: 21Last Post: 08-10-2010, 04:21 AM -
Cam Bearings
By slacker4321 in forum Internal EngineReplies: 1Last Post: 01-14-2009, 11:25 AM -
ls1 bearings
By wesmc in forum Internal EngineReplies: 4Last Post: 04-04-2008, 12:12 PM -
Do I need new cam bearings?
By phoenix1987 in forum Internal EngineReplies: 1Last Post: 08-24-2006, 02:20 PM
