Results 1 to 3 of 3
Thread: Wheel Bearing help!
03-29-2008, 04:18 PM #1Junior Member
- Mar 2008
- california
Red- 2002 Z28
Wheel Bearing help!
i'm hearing a growling,thumping noise coming from the right side rear of the car. i'm about 90% its a bearing. any help on this install? is it a pita to do??
03-29-2008, 06:17 PM #2
Axle bearings are fairly easy to do, but don't wait. The axle itself is the inner race so if you start to chew that up you'll be in for an axle too. First step is get the rear wheels off the ground and try to locate the noise, swap tires, check lug nuts, etc.
03-29-2008, 10:59 PM #3We'll be back...
- THE SWAMP
Does the noise change pitch while you dive?
Wheel Bearing?
By wildbanshee in forum General HelpReplies: 9Last Post: 01-29-2012, 09:37 PM -
Wheel Bearing
By vetteemt in forum General HelpReplies: 9Last Post: 09-30-2009, 05:56 PM -
wheel/pinion bearing?
By mpowell04 in forum DrivetrainReplies: 7Last Post: 06-20-2008, 10:41 AM -
Anyone ever had a rear wheel bearing go out?
By Fred H. in forum DrivetrainReplies: 2Last Post: 05-01-2008, 01:47 PM -
bad hub/wheel bearing?? please help
By shaunls1 in forum Suspension and HandlingReplies: 2Last Post: 12-13-2007, 10:46 AM
