Results 1 to 10 of 10
Thread: Wheel Bearing
09-02-2009, 04:03 AM #1Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
Wheel Bearing
So driving down the road for no apparent reason a loud high pitch sequel came from the front drivers side tire. It lasted for a few seconds and then went away, then came back about 10 mins later then stops right before I got to work. It sounds like a wheel bearing went out I have 82K on the original ones, but just wanted to post to see if it could be some thing else since a new bearing assemble is $311.00. The car drives fine, does not pull, and the wheel assemble is not hot to the touch, it just makes the high pitch sequel.
1998 Camaro SS Hard Coupe Bright Red #1593
Mods: Lots!!, still my daily driver except for winter
383rwhp 370rwft/lbs
1979 Corvette
Mods Lots!!, weekend cruiser
325rwhp and 320rwft/lbs
2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
Mods: Catback, BFI CAI, Winter daily driver
09-02-2009, 05:24 AM #2
how many miles are on your brake pads? Sure it's not the pad sensor rubbing the rotor?
09-02-2009, 05:51 AM #3Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
Only about 15K on the pads and rotors, This happens when I'm just driving down the Hwy. Not when the breaks are applied.
09-02-2009, 06:13 AM #4Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
I have close to double your mileage & my bearings are fine(checked 2K ago)
Had a noise like that on a pickup truck & found a small stick had lodged up in the caliper.
Jack it up & check them for play, spin them & check for noise.
09-02-2009, 08:15 AM #5Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
I'll do that when I get home. Also thought that it might be a pulley on the engine or power steering pump going stupid?? When I find out what it is I'll post it.
09-02-2009, 01:42 PM #6
09-02-2009, 06:43 PM #7Senior Member
- Apr 2008
- Madison, WI
Wheel bearings don't really squeal on and off. When they go bad they make a humming noise. And the noise gets louder when you turn one way (put more load/weight on it) and get quieter turning the other way.
09-03-2009, 02:54 AM #8Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
So when I got home I put the car on a friends lift and we checked all the wheels, power steering pump, idler pulleys, belt, and we found nothing. Also of course it has not make a noise since yesterday morning.
09-30-2009, 05:53 PM #9
how do you change the bearings on the rear, i haven't been able to find any good write ups
09-30-2009, 05:56 PM #10
nevermind i think i found one...i know they are sealed units i was just looking at on how to replace them
Wheel Bearing?
By wildbanshee in forum General HelpReplies: 9Last Post: 01-29-2012, 09:37 PM -
wheel/pinion bearing?
By mpowell04 in forum DrivetrainReplies: 7Last Post: 06-20-2008, 10:41 AM -
Anyone ever had a rear wheel bearing go out?
By Fred H. in forum DrivetrainReplies: 2Last Post: 05-01-2008, 01:47 PM -
Wheel Bearing help!
By mrz28m6 in forum General HelpReplies: 2Last Post: 03-29-2008, 10:59 PM -
bad hub/wheel bearing?? please help
By shaunls1 in forum Suspension and HandlingReplies: 2Last Post: 12-13-2007, 10:46 AM
