Results 1 to 10 of 10
Thread: cant get it into gear?
03-26-2008, 01:13 AM #1Junior Member
- Mar 2007
- Azusa, CA
RED- 99 ss camaro
whats the problem my car only has 60,xxx miles on it and i have a FX400 Clutch on it. recently i been having problems getting the car to go into the gears and sometimes its so hard to get into reverse that it grinds. please help
03-27-2008, 09:13 AM #2Member
- metro Detroit area
Sounds like your new clutch is dragging. Prove it to yourself= with the engine off, how easy is it to get into gear?
03-27-2008, 11:34 AM #3Junior Member
- Mar 2007
- Azusa, CA
RED- 99 ss camaro
Its alot easier to get into gear. could it be my hydraulics?
03-27-2008, 11:38 AM #4
sounds like hydraulics
03-27-2008, 11:59 AM #5Member
You could do a pressure( vac actually) bleed before you tear into it. There could be an internal leak in the slave that doesn't show up externally.
03-27-2008, 12:33 PM #6
Not sure on your camaro, But on my 240 I can adjust my slave, It has a adjustable rod from the pedal to the slave on the firewall.
03-28-2008, 04:01 AM #7Member
Unless its been altered or has aftermarket parts, these are not adjustable .
03-30-2008, 12:45 PM #8
But they are sorta adjustable. Shims between the slave and mount on tranny. Shifter could be loose too, that can cause issues as such. Could be a simple fix. But could just as easily be a bad clutch. best of luck to you.
03-30-2008, 03:30 PM #9
Sounds like your pressure plate might be getting weak.
03-30-2008, 09:32 PM #10Junior Member
- Mar 2007
- Azusa, CA
RED- 99 ss camaro
I bought a new master cylinder will be putting in next week i hope it works its the third i put in.
Sticking in gear / not going into gear
By Dave-TransAm in forum V6Replies: 1Last Post: 08-17-2012, 01:56 AM -
Pro Gear ($900) vs SD Gear&Axle ($570)??
By Z28er in forum Western MembersReplies: 7Last Post: 04-29-2010, 07:47 AM -
2002 Camaro ss a4 Help! redlines a gear then changes a gear from a roll please read!
By hmorris7000 in forum Camaro / SSReplies: 24Last Post: 06-05-2007, 03:01 PM -
By hmorris7000 in forum General HelpReplies: 9Last Post: 06-01-2007, 05:18 PM -
Z06 on top gear
By oneBADDz in forum Almost Anything GoesReplies: 22Last Post: 05-20-2006, 09:11 AM
