Results 1 to 20 of 25
06-01-2007, 05:30 AM #1
2002 Camaro ss a4 Help! redlines a gear then changes a gear from a roll please read!
When i put the petal to the floor when i driving about 40mph to 85 mph it automatically goes to red line and sets there for a min then finally shifts in to a pulling gear if i was racing just that wait alone would make me lose why is it doing that? it goes and sits in the red area for a sec or two revs real high then shifts to pull but it takes a min to get for red to actually pull i think its shifting to low when i mash to the floor for a roll, can u help?
06-01-2007, 09:33 AM #2
06-01-2007, 09:37 AM #3Junior Member
- Dec 2006
- Canada
i dunno about that... when my MAF was on its way out my tranny was shifting for crap.. check make sure ur mafs not out.. is there a CEL or SES?
06-01-2007, 09:38 AM #4
Really???? When I drive regular speed and normal driving everything is just fine is just when i mash it to the floor also i assume im in fourth gear and when i mash it isnt 2nd a lil low for it to reach to? i thought maybe thats why it was redlining and holding cause it shifted to a to low gear.
06-01-2007, 09:39 AM #5
cel or ses? dnt know what that means
06-01-2007, 09:42 AM #6Just me
- Nov 2006
- Broken Arrow, OK
When I had to have my tranny rebuilt it was doing the same thing, under WOT it wouldn't shift from 2nd to 3rd, it would just redline and stay there for a few seconds because it can't shift. I have experienced this before, your tranny is most likely dying.
06-01-2007, 09:43 AM #7
06-01-2007, 05:52 PM #8
most likley ur sinchro's are out. Like mentioned above time for a trans rebuild. I got my work done from T56 rebuilds
06-02-2007, 09:45 AM #9
no ses orcel lights to come on
06-03-2007, 03:52 PM #10Junior Member
- Dec 2006
- Twin Beaches MD
SOM- '01SS Camaro,'09 Z06
My 01 SS does what sounds like the same thing, when I'm rolling along and floor it, it drops out of 4 and slips or rev's up before it hooks up, I'm talking milli-seconds, not minutes, never hits the rev limiter, but when it hits it hits hard going into 1st or 2nd, shifts fine under power in upshifts from 1-2, 2-3 and 3-4. I wondered if it didn't have something to do with the torque convertor?
06-03-2007, 05:05 PM #11
06-03-2007, 06:52 PM #12Member
- Aug 2006
- Tulsa, Oklahoma
Navy Blue Metallic- 2001 camaro SS A4
[SIGPIC][/SIGPIC]
SS #2988, A4, Navy Blue Metalic, 335HP Dual Dual Exhaust, Chrome 10 spokes, Floor mats, Dash plaque, and SS Grille
Best ET 13.08 @ 106.1, 2.00 60', with SLP lid
06-04-2007, 04:11 AM #13
Frankly... if you're gonna race... it's always best to shift your auto. ... unless it's right out of the blue and you don't have time to... but if you downshift yourself to a safe yet strong gear... you wont have that problem... cause you'll already be in gear...just like in a manual... downshifts might hurt the tranny a bit though if you try to go too low...
Mods: SLP Air Lid w/ KN, Free-Mods, LS6 Manifold, Magnaflow, Headers, EFILive
Visuals: Angel eyes, rear eurolights and T/A rims
Suspension: Eibach ProKit, UMI Adj. Panhard, SFC's, LCA Relocation brakets, KYB AGX shocks
http://www.fquick.com/garages/Chevro...28/1999/23674/
06-04-2007, 09:19 AM #14
Don't shift the auto's manually, there is no need for it. Thats the beauty of an auto, it does it for you. Once your shift points are set where they need to be for a particular combo, just put it in overdrive and there is no need to ever touch the shifter again.
If you want it to downshift earlier or hold gears longer for higher RPM shifts then it should be done in the tune,,,not with the shifter
06-04-2007, 04:17 PM #15Junior Member
- Dec 2006
- Twin Beaches MD
If dragging I agree, I've tried several time to get it to upshift on my schedule only to bounce the rev limiter, the few times I've nailed it the tires spin into second, yet there are many times when I want to use engine braking and other advanced uses of the trottle, such as controlling wheel spin. But you are right no need to shift them going in a straight line.
06-04-2007, 05:09 PM #16
I knocked 3 tenths out of my Quarter Mile time... by shifting myself... bone stock... so...don't knock it till you learn how to do it properly... trick is to shift it at about 5,200rpm and it'll shift perfect...
06-05-2007, 05:18 AM #17
I have tried it with many cars. Fact is,,,if your car is running better by shifting it manually, then all that tells me is you need to go in and play with your transmission shift points in your tune, because the computer is not commanding your shift points at optimum times.
Once you have them set properly then there is no need to ever touch the shifter.
06-05-2007, 05:19 AM #18
But the car was absolutely stock... I didn't mess with it... so it's suposed to shift as for factory specs...
06-05-2007, 05:45 AM #19
Ya I know,,,,sometimes GM don't have these things setup perfectly,,,,mine would shift too early out of first gear, and then hold the 2-3 shift to redline
so I had to play with my shift points in HPtuner to get it where it ran the best. I took several passes, but once it's set right, it saves you the trouble of having to shift it yourself. It's nice to mash the gas and let the car do it's thing, you can concentrate more on reaction times and keeping the car straight. Thats what auto's are for
I have a 6 speed car too and it's nice to hang gears and all that, but I jump in the auto so I don't have to,,,know what I mean?
06-05-2007, 05:59 AM #20
yeah... I get ya... but I also like knowing that I had a part in it... hehe... I mean... my reaction times are usually near perfect cause I have the timming set up for the one track in the near area... I'd love to have a M6... but they are just literally imposible to find here...
Sticking in gear / not going into gear
By Dave-TransAm in forum V6Replies: 1Last Post: 08-17-2012, 01:56 AM -
Pro Gear ($900) vs SD Gear&Axle ($570)??
By Z28er in forum Western MembersReplies: 7Last Post: 04-29-2010, 07:47 AM -
2002 ss gear ratios
By rapidride2 in forum Camaro / SSReplies: 2Last Post: 06-17-2007, 09:21 AM -
By hmorris7000 in forum General HelpReplies: 9Last Post: 06-01-2007, 05:18 PM -
What gear is in a 2002 Ws6
By Kup98ss in forum Firebird / WS6Replies: 15Last Post: 05-08-2007, 03:58 PM
