Results 1 to 16 of 16
Thread: trex cam
    ne kansas
    01 Z28
    trex cam
    is the trex v.2 a good cam for stock heads?? should i upgrade srings and rockers or what all should i do?? please help i dont want to mess anything major up. thanks in advance
    01 z28 m6 free mods, cai, loudmouth, long tubes
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    Quote Originally Posted by gsxrsteve View Post
    Awefull big cam what are your plans? A bigger cam is not always the answer.
    Denton (Dallas)
    2003 GTI 1.8T :(
    you are talking a large cam... with any swap you will need new springs etc... but what made you chose this cam? it can use stock heads but you wont really get much use out of it unless you upgrade the heads and use a smaller gear like... 4.10 or smaller
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Hey guys, that cam is actually designed for max effort-type cam only setups and yes, actually, stock heads.
    Go heavy on the springs if you are an M6, get good pushrods and light rockers are nice if in the budget. That cam will like the Fast 90 intake as well.
    I wouldn't want it in anything that I ever had to drive as a primary vehicle.
    Denton (Dallas)
    2003 GTI 1.8T :(
    but he needs a 4.10-4.56 gear set or so correct?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by BULLET_WS6 View Post
    yeah and a 5K stall if an auto
    ne kansas
    01 Z28
    sorry ya its a m6. So my stock heads should me ok with some new springs and rocker?? correct? i want that crazy ass lope a big cam has
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    stock rockers are fine.... it'll lope, but it's not how I would go about finding it.
    15 sec. Oh yeah, its fast UTVols98's Avatar
    Forest Lake, MN
    maroon
    2000 Z28
    Double valve springs and hardened pushrods will be a must with that cam. You might need to check the PTV clearance with the long duration of the cam and might want to flycut the pistons just to be safe. Definitely get the 4.10's to take full advantage of the cam.
    ne kansas
    01 Z28
    ptv ?? piston to valve
    Forest Lake, MN
    maroon
    2000 Z28
    Yep. I don't think you'll have a problem though with the stock heads.
    ne kansas
    01 Z28
    so that cam is a go??
    Forest Lake, MN
    maroon
    2000 Z28
    Your good, but look into an LS6 or FAST intake if your gonna run that cam.
    ne kansas
    01 Z28
    thanks for the info
    Marylandistan
    2001 Trans Am (sold)
    Frost is rite. Designed to work with stock heads. Strong numbers put out by this cam on dyno and track. Check LS1 Techs top fastest cam only list. Several of them running this cam. http://www.ls1tech.com/forums/showthread.php?t=187330
    Tulsa, ok
    TRex is designed for stock heads.
  1. Trex cam....?
    By Lunatikgixxer in forum Internal Engine
    Last Post: 06-19-2011, 10:30 AM
  2. Trex on A4
    By Tonokologo in forum Internal Engine
    Last Post: 02-01-2010, 10:11 AM
  3. Trex Vs Ms4???
    By blackls1ta in forum Internal Engine
    Last Post: 08-16-2007, 01:12 PM
  4. 98 TA Trex Cam only car For Sale!!!
    By TN94z in forum Vehicles For Sale / Trade
    Last Post: 03-21-2007, 09:11 AM
  5. NE-1 spray the TREX??
    By 98_Formula in forum Nitrous
    Last Post: 04-30-2006, 06:12 PM
