Results 1 to 20 of 27
Thread: Trex Vs Ms4???
    Member blackls1ta's Avatar
    kittanning,pa
    2000 ws.6 m6
    Trex Vs Ms4???
    which would be a better cam for the street with a set of afr 205cc heads,i am looking to do a head and cam swap in the spring just wanting some good opinions which would be a killer street cam without too much hassle trex or ms4 any help would be greatly appreciated.
    For the street?? Neither cam.
    228R from TSP.
    kittanning,pa
    2000 ws.6 m6
    228R from TSP.
    whats the lift on it will i still be able to get 420 at the wheels with that one?
    If you want a street car...don't concern yourself with peak dyno numbers.
    You want more powerband. But the right tuner might be able to get 420 out of that cam with ALL the bolt ons.
    kittanning,pa
    2000 ws.6 m6
    i talked to tsp they gave me this info on what to buy for street setup,precision race components stage2.5 5.3L heads with a torquer v.3 cam comes with hardened pushrods,extra cost for ported oil pump,head gasket kit,cam specs are 231/234 643./598 111lsa,AND adjustable double roller chain for total of 2050 sound like a good deal?
    Other than the double roller chain, sounds like a great set-up.
    kittanning,pa
    2000 ws.6 m6
    why shouldnt i need the double roller chain?
    Overkill in my opinion.
    Plus, they can create install issues.
    I went with the Comp adjustable single set for mine.
    kittanning,pa
    2000 ws.6 m6
    oh ok, they have non adjustable single roller chain for less,so i really dont need the double even know a shop will installin all this?
    Member SAGGIN's Avatar
    Elk Grove, CA
    RED
    02 SS, 03 BMW 745
    I don't think you'll have touble finding a shop that'll install all of what you have listed but to tune the car so that your in the ballpark area in terms of HP may be a little more difficult.
    Quote Originally Posted by blackls1ta View Post
    The double increases the width of the chain. Sometimes makes the crank pulley and timing cover fit funky.
    I run a single chain.
    Done me perfectly fine so far....8500 miles.
    Numbers in sig...all motor.
    Lowered, HID's, tinted.
    kittanning,pa
    2000 ws.6 m6
    Quote Originally Posted by SAGGIN View Post
    that shouldnt be too hard im not far from pittsburgh theres alot of good shops around
    LS1 powered LT1 Z28 95GreenZ28's Avatar
    Amarillo, Texas
    Polo Green Metallic
    1995 Camaro Z28
    just run a ls2 timing chain. I am running the 231/237 cam with a ls2 timing chain. Man I wish you lived here and I would put it all in for you for cheap
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    228R from TSP.
    I beg to differ. I daily drive mine and it is great. I got my idle at 925rpm (had it at 850rpms with no problems) but liked the off idle throttle response a bit better at 950rpms especially when Auto-Xing at our slow small events. At 850 the lope is awesome. There is a bit of bucking but other than that it drives perfect. I get about 22mpg in the highway and 12mpg in the city around 17 combined when driving to work. Rush hour is no problem. Drivability is all in the tune (although anything bigger would make it harder to get it livable). Low end torque is not bad. I have to take go to the dyno to put some final touches to the tune after I put my new clutch in and get some final numbers. The cam has a awesome top end 3K and up it just pulls and pulls all the way to redline.
    I think a Trex takes a bit more work to get decent any drivability.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Everyone has their own opinion of streetable. I do agree that a good tune will make the biggest cams easy to drive.
    Do you have a dyno sheet available?? Those larger cams like the higher RPM's. Off idle won't be bad, I agree.
    But with the slightly smaller cams you can get a larger powerband. Which for me is something a street car needs.
    Everyone has their own opinions though. Hell...I run a 248/254 629/622 113.
    North Olmsted, OH
    No the only graph I had was when I was running it with stock manifolds, ORY and Borlamouth. As you know this big overlap cams don't do too well with restrictive exhaust. It still manage to pull 385 rwhp can't remember the torque. Due to some circumstances (relating to been ripped off on my original cam selection that was suppose to be a TSP 231/237 598/595 LSA114 and turned out to be a stock cam) I had to get another cam in there before I got long tubes on the car. So at that point I though that if I was going to do another cam swap 2 weeks apart from each other I might as well get something a tad bigger .
    Nice! is it straight up or do you have any advance on it? I would have loved to have done a custom MS4 239/242, .649"/.609" 110*+2 but I would have had to flycut. So I went with their standard 111* grind.
    Straight up. In a 402.
    Are you geared?
    Member sfletch2000's Avatar
    Feb 2007
    Bakersfield, CA
    86 Buick Grand National
    02 WS6-M6 407 RWHP
    Check out my sig, i'm running TSP's 228R LSA-114
    Pacesetter Headers- ORY
    Texas Speed 228R Cam/Moly Pushrods/918 Springs
    MTI LID
    Slp Under Drive Pulley
    Texas Speeds Rumbler Catback
    SFC's, Lakewood LCA's
    Koni SA 4/3, Strano Springs
    Dyno Tune
    LS7 Clutch, Nitto DR's
    407 RWHP 377 Ft./lbs.
    kittanning,pa
    2000 ws.6 m6
    Quote Originally Posted by 95GreenZ28;931163rive truck so im all over but finding a goo
    well yeah thats sucks live fartheraway id get you to install but i also want a good tune on it
    KWK N NUF TheKitchenSink's Avatar
    Arlington Heights, Illinois
    2001 Trans Am WS6
    Ive got the TSP228R and made 411 hp through an automatic w/ bolt ons. Seeing your m6, I don't see why you couldn't hit 420.
    Pacesetter Headers & ORY, Magnaflow Catback, P&P TB, Koni SA Shocks, Strano Lowering Springs, TSP228R, PRC Dual Valve Springs, LS6 Ported Oil Pump, Vig. 3200 Stall, TransGo Shift Kit, Trans Cooler, Spohn Panhard Bar, UMI Rear LCA's, Relocation brackets, Torque Arm SFC. 411 hp / 386 ft/tq
  1. Trex cam....?
    By Lunatikgixxer in forum Internal Engine
    Last Post: 06-19-2011, 10:30 AM
  2. Trex on A4
    By Tonokologo in forum Internal Engine
    Last Post: 02-01-2010, 10:11 AM
  3. trex cam
    By gsxrsteve in forum Internal Engine
    Last Post: 04-04-2008, 12:14 PM
  4. 98 TA Trex Cam only car For Sale!!!
    By TN94z in forum Vehicles For Sale / Trade
    Last Post: 03-21-2007, 09:11 AM
  5. NE-1 spray the TREX??
    By 98_Formula in forum Nitrous
    Last Post: 04-30-2006, 06:12 PM
