Results 1 to 20 of 109
Thread: Strange S60 or 12 Bolt?
03-20-2008, 08:33 AM #1
I am looking into a new Strange Rear I am kind of confused as to whether I should go with the S60 or the 12 bolt drop in rears for my 02 TA. Any help? Also what ABS do I go with 3 or 4? I need it to be a direct bolt in, I want to keep the brakes stock if I have 2.
Thanks
03-20-2008, 08:38 AM #2
3 channel, do you have traction control?
03-20-2008, 08:40 AM #3
no i don`t believe i do.
03-20-2008, 08:41 AM #4
are you sure you dont have traction control that little switch that would be next to your right knee??
03-20-2008, 08:50 AM #5
no i do not it would be in front of my sticj shift in the square empty compartment ( wouldnt be empty if I had it)
03-20-2008, 08:51 AM #6
good deal its the 3 channel, do you want to keep ABS? cause its 200 option i believe
03-20-2008, 08:52 AM #7
I am not sure what I want to do yet, The car is a daily driver even though I do not drive it daily. What would you do?
03-20-2008, 08:58 AM #8M6 King
- Mar 2006
- WI
- Blog Entries
- 1
I'm leaning towards the 9". It's stronger than the 12 and lighter than the 60. I'm still researching them though.
03-20-2008, 08:59 AM #9
i got a 9" with a spool, and no traction control cause u cant with a 9" and it was the strongest rear other then the S60 for the least amount of money
03-20-2008, 08:59 AM #10
03-20-2008, 09:00 AM #11
my 9" with the spool its the lightest rear you can get and i got the alum center section
03-20-2008, 09:01 AM #12M6 King
- Mar 2006
- WI
- Blog Entries
- 1
03-20-2008, 09:02 AM #13M6 King
- Mar 2006
- WI
- Blog Entries
- 1
03-20-2008, 09:22 AM #14
you guys have pictures of your 9" installed?
03-20-2008, 09:28 AM #15Slow'er'Ass
- Thornton, CO
Lowered, HID's, tinted.
03-20-2008, 09:29 AM #16King 0f n00bz
- Jan 2006
- Shepherd, Michigan
also worth noting is that the 9" is the lease efficient of the 3 rear ends..so even tho its lighter it still eats up power. The new strange dana s60 is built to be a direct bolt on for f-bodies..it also is the strongest and the most efficient...there will be no questions when i decide to get a new rear...it will be a dana s60
03-20-2008, 09:31 AM #17Slow'er'Ass
- Thornton, CO
The 12 bolt and the Dana rears scare me when it comes to the torque arm bolting on.
If it breaks...the whole rearend is trashed.
I went 9". Torque arm bracket brakes?? Replace the bracket, not the whole rearend.
Will most have to concern themselves with breaking that?? No.
If I had to do it again...I would go with the same thing I did, but with the aluminum center section.
TruTrac Moser 9"
31 spline
4.11's
03-20-2008, 09:37 AM #18
03-20-2008, 09:37 AM #19King 0f n00bz
- Jan 2006
see now i have hear horror stories about moser...i heard strange is slllllllllllllllllooooooooooooooowwwwwwwwww with getting you their rear. Dont get me wrong C..i dont mind the 9" but its not necessarily a bolt on rear end..and plus you trade off efficiency for the strength..so why not go with even more strength and the best efficiency that actually outweights the lose in weight....p.s get on aim..i need to im you
03-20-2008, 09:38 AM #20
Question: 12 bolt strange
By WARP211 in forum DrivetrainReplies: 0Last Post: 03-04-2009, 11:25 AM -
s60 vs strange 12 bolt
By scabbedwings616 in forum DrivetrainReplies: 24Last Post: 01-16-2007, 03:54 PM -
Where should I buy a Strange 12 bolt?
By kevinpickering in forum DrivetrainReplies: 16Last Post: 12-06-2006, 08:30 PM -
12 bolt or Strange S60?
By Spaz in forum DrivetrainReplies: 11Last Post: 11-11-2006, 08:01 AM -
Strange 12 bolt f/s
By 99RedRagtop in forum Parts For Sale / TradeReplies: 5Last Post: 09-13-2006, 08:33 PM
