Results 1 to 17 of 17
    Junior Member kevinpickering's Avatar
    Warrenton, MO
    Blue
    1999 Camaro SS
    Question Where should I buy a Strange 12 bolt?
    Hey those of you with Strange 12 bolts... Where did you get them and where can I get a good deal?? I going to be spending around $2500, right?? Oh and Happy Thanksgiving!!!!
    Junior Member Z95SSCLONE's Avatar
    LA
    95 Z28
    got mine from spohn. i think it was like 2700
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    If you have any local chassis shops they should be a Strange dealer.......It's all about finding a local good deal. Where are you at....?
    Warrenton, MO
    Blue
    1999 Camaro SS
    St. Louis, MO
    Indianapolis, IN
    2002 Trans Am WS6
    I bought mine from Tbyrne, and drove 4 hours to Chicago to pick it up (saved $400 in shipping).
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Our Sponsors!
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Philly area
    is this a kit that stengthens the stock 10 bolt so I don't have to buy a 12?
    http://www.ws6project.com/user_stor/...1f9943b8832db4
    stab it and steer it!
    Aug 2006
    illinois
    99 Z28 SS convertible
    that is just an axle kit. the axles aren't that bad in the stock 7.5s. the problem is simply the size and design of the ring and pinion assy. the car is heavy enough and with any kind of tractrion at the tires, the diff will fail before the axles. if you have a manual transmission, the rear is much more probable to break. if you have an auto and no transbrake, the car will safely run into the 10 sec. range with a few modifications to the 10 bolt. after that don't mess with the stock rear.
    Philly area
    Quote Originally Posted by 99RedRagtop View Post
    I have A4, so ur saying get the 3200 stall, 3.73 gears and run 500rwhp on stock 10 and it is fine? I do intend to make that much power in a year or so, this is why I am in the dillema with the rear end bolt size... many people say go 12 since you'll break it in the scenario above.. so? hmmm what is the smart thing to do? just consolidate the 10bolt somehow? with what kits?
    Aug 1999
    No Where
    You may last, I have. But I plan on a 12 bolt.
    Philly area
    I may keep that 10bolt, do 3.73 gears, stall it and AFR/cam.. and call it a day.. that will put 460rwhp. and then when I want more juice in a few years I'll throw in the procharger and change the to 12bolt + new gears set at that point,.. yeah.. it may be cool that way.
    Aug 2006
    illinois
    ed's rear is completely stock... he's been lucky. that car runs well! my own is a 'vert also, and with the heavier weight, slicks and all, the 10 bolt is holding up fine. i did the work to mine myself. installed a new Eaton posi, 3.73s, solid pinion spacer, and LPW rear cover. thats about all i would wanna do to one. any more than that and it wouldn't be worth the money. you'd be money ahead to just go to the 12 bolt or S60 (Strange only)
    Philly area
    you saying i'd be wasting my money on 12bolt correct?
    Indianapolis, IN
    2002 Trans Am WS6
    Mine failed at 35K miles on almost stock HP.
    Philly area
    shoot, that sucks mate..
    Aug 2006
    illinois
    not necessarily... heres the deal. if you do a good posi, gear, install kit, cover, solid spacer, synthetic lube, etc... you're looking at around 900-1000 in just parts! add labor to that and you're getting within the range of buying a new S60 rear completely assembled from Strange. its just the bang for the buck issue. why spend that kind of money on the 10 bolt and still have a 10 bolt whern you're done? although the 10 bolt will live w/ A4 under 500 whp.
    Aug 2006
    illinois
    Quote Originally Posted by rbrack View Post
    you have a manual trans?
  1. Question: 12 bolt strange
    By WARP211 in forum Drivetrain
    Last Post: 03-04-2009, 11:25 AM
  2. Strange S60 or 12 Bolt?
    By Patsy57 in forum Drivetrain
    Last Post: 07-17-2008, 04:01 PM
  3. s60 vs strange 12 bolt
    By scabbedwings616 in forum Drivetrain
    Last Post: 01-16-2007, 03:54 PM
  4. 12 bolt or Strange S60?
    By Spaz in forum Drivetrain
    Last Post: 11-11-2006, 08:01 AM
  5. Strange 12 bolt f/s
    By 99RedRagtop in forum Parts For Sale / Trade
    Last Post: 09-13-2006, 08:33 PM
