Thread: poly mounts
    Marshfield Missouri
    poly mounts
    how hard is a poly motor mount install on a 2001 trans am?
    Not easy.
    The passenger side is really not any fun.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Yes it's a PITA,
    Driver side took me 5 Hrs.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Tire Smoker Jeff2002WS6's Avatar
    Anderson, IN
    2002 Pontiac Trans Am WS6
    My big problem was getting everything to line up again. Had to use an air hammer to drive in the long through bolt on the passenger side. Just couldn't get it to line up and go with a jack and pry bar.
    Member hoss 2000 z-28's Avatar
    Jeffersonville, Indiana
    Monterey Maroon Metalic
    2000 Z28
    PITA but worth it in the long run.
    Chowchilla CA
    2001 Z28
    If you are taking the engine out of the frame, just do it. You will have a little more vibration, but they work. Just putting them in by themselves is probably more trouble than its worth.
  1. Poly motor mounts
    By Supersport0126 in forum Camaro / SS
    Last Post: 01-29-2012, 02:19 PM
  2. Question: Poly or OEM motor mounts?
    By allbaugh_04 in forum External Engine
    Last Post: 07-08-2011, 10:42 AM
  3. Will poly mounts cause vibrating.
    By Street Fighter in forum Suspension and Handling
    Last Post: 05-16-2008, 06:15 PM
  4. wtb: poly motor mounts 99 ta
    By white99 in forum Parts Wanted / Trade
    Last Post: 04-09-2008, 06:22 PM
  5. poly mounts and pacesetters
    By 2000 ss in forum External Engine
    Last Post: 02-03-2008, 11:38 AM
