Thread: Poly motor mounts
01-24-2012, 05:25 PM #1Member
- Aug 2011
- pittsburgh,pa
navy blue- 1998 camaro ss
Poly motor mounts
Doin poly motor mounts on 98 ss. Got driver side in, if I unbolt the manifold on the passenger side to get the mount out (proper procedure?) Will the manifold gasket be ok to just bolt back up? And will I be able to pull the manifold back enough to get the mount out withoit unbolting anthing else?
01-24-2012, 05:35 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
If it still has the stock steel gaskets reusing them should be fine. Might have a little trouble just moving the manifold with the rest of the exhaust in the way though.
01-28-2012, 01:51 PM #3
I was able to do motor mounts without removing manifolds. It was a pain, but doable.
01-29-2012, 02:19 PM #4Junior Member
- Aug 2010
- Wisconsin
Red- 2000 Z28
Same here took off the starter and worked from the bottom big pain though
Question: Poly or OEM motor mounts?
By allbaugh_04 in forum External EngineReplies: 12Last Post: 07-08-2011, 10:42 AM -
wtb: poly motor mounts 99 ta
By white99 in forum Parts Wanted / TradeReplies: 0Last Post: 04-09-2008, 06:22 PM -
just put poly motor mounts on, can I leave the hea
By KiloVictor in forum External EngineReplies: 2Last Post: 03-19-2008, 03:11 PM -
NIB: 98-02 LS1 Poly Motor/Tranny Mounts $50
By CWW17 in forum Parts For Sale / TradeReplies: 5Last Post: 11-20-2007, 12:36 PM -
Vibration with poly motor mounts and cam?
By Huskerz1 in forum External EngineReplies: 4Last Post: 06-12-2007, 10:59 AM
