Thread: What do you suggest
03-12-2008, 11:03 AM #1
What do you suggest
I have a 98 ss with the ls1 6speed 131000 miles on it I want to do sometype of fuel system and engine treatment to clean it all out I've read some good and about about b12, seafoam and lube control but the lube control looks more preventative not some much cleaning out whats already in there any suggestions.
03-12-2008, 11:12 AM #2Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
change the oil and the plugs, fuck all those bullshit additives, i would never run the risk of running that on a customers car little own mine
03-12-2008, 11:52 AM #3
what do you suggest to clean the system out then fluids and plugs have been done and I do regulary. while were on plugs to I changed mine at about 85k I put ac delco plugs back in it any suggestions when i should change again and should i stick with ac delco or is there something else
03-12-2008, 01:21 PM #4Senior Member
- Jun 2007
- corona ca
i like the granatelli wires, the ngk tr551x's. i would change the fuel filter and clean the maf, thats about all i would do, and then if you want you can run auto rx, check them out at autorx.com this stuff works very well. thats all i would do, you got tons of fun miles ahead of you
03-12-2008, 02:52 PM #5
03-12-2008, 02:58 PM #6
Dont forget about your local GM dealer and the BG fuel induction service!! hahaha sorry, sales pitch from a service adviser!
2018 Tahoe - Silver - OEM
Check my list of mods and suggest what to do next
By Hurley711 in forum General HelpReplies: 5Last Post: 06-20-2010, 07:59 PM -
Suggest A New Years Resolution FOR OTHERS
By ARM5280 in forum Almost Anything GoesReplies: 0Last Post: 01-13-2009, 11:02 AM -
re build 4L60E what do you suggest?
By vxchev8 in forum Automatic TransmissionReplies: 30Last Post: 09-23-2007, 11:25 AM -
What options do you suggest for a new Vette in CA?
By brushrunabout in forum CorvetteReplies: 2Last Post: 09-05-2006, 02:49 PM -
What heads do you suggest???
By smiggs44 in forum Internal EngineReplies: 8Last Post: 02-03-2006, 01:50 AM
