Thread: voltage problem
03-11-2008, 09:34 PM #1Junior Member
- Dec 2007
- Alvarado TX.
white- 96 TransAM/ 05 Expedition
voltage problem
what would cause my battery guage to drop down into the red and my check guages light comes on when getting on my car. It don't do it until around 4500 rpm and up. When driving around normal it won't ever do this. Also when driving my tach will be bouncing up and down. Say if i was running about 2500 rpm it would be bouncing from about 2000 rpm to 3000 rpm.
03-13-2008, 03:49 PM #2Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
03-13-2008, 03:54 PM #3
could be the alt. going south. check your output current and voltage on the alternator while revving it up
03-13-2008, 03:57 PM #4
I suggest finding out exactly what your alternator putting out. To do so you'll need a multimeter. I understand it only does it while driving and at 4500 rpms. However I'd still hook up a meter and rev it up and see exactly what your getting 1st. It could be a faultly gauge or it could be a true electrical problem. If its confirmed you voltage is dropping like you say it is, I'd check for loose connections. Ex alternator, gauges anything like that.
TPS voltage
By 98TransAmWs-6 in forum General HelpReplies: 29Last Post: 04-26-2016, 08:51 PM -
Low Voltage, Why?
By Z28boy2000 in forum General HelpReplies: 32Last Post: 02-27-2014, 05:17 PM -
Low Voltage
By adamz02ss in forum General HelpReplies: 16Last Post: 08-08-2012, 03:22 PM -
Low voltage
By Art99SS in forum General HelpReplies: 1Last Post: 06-02-2009, 03:34 PM -
voltage
By tingo99 in forum Internal EngineReplies: 5Last Post: 08-06-2008, 05:47 AM
