Results 1 to 17 of 17
Thread: Low Voltage
11-21-2011, 05:03 AM #1Junior Member
- Apr 2010
- Virginia
Onyx Black- 2002 Camaro SS
Low Voltage
I started my car this morning and the voltage gauge was laying right on the edge of the red. After I drove for about 20 minutes the meter went up to the halfway mark then it dropped back down to halfway between 13 and the red. My first thought was my alternator is going bad. My Optima battery is about 2 years old in it. Any thoughts?
11-21-2011, 08:46 AM #2
I would first check to make sure that all your wiring is connected securely; at the battery and alternator. Make sure all the connections are clean and free of corrosion build up.
If that all checks OK, I would have both the battery checked and the alternator.
If you charge your battery with a charger and in a few days the battery is dead again, you either have a faulty cell in the battery or you have something draining the battery; bad fuse, power usage, etc.
11-21-2011, 08:49 AM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Agree wih Jon.
11-21-2011, 08:50 AM #4Spaz is My Mentor
make that +2 with Jon
11-22-2011, 04:39 AM #5
11-22-2011, 05:50 AM #6Junior Member
- Nov 2011
- Houston, TX
Pewter- 1999 LS1 Transam
Im having a similar problem with my car. Any ideas on why my alternator willnot charge my battery? Ive been to three shops my back is against the wall, Ive replaced the car with a brand new computer, alternator, and battery yet my car will not charge!!! Any Ideas would be greatly appreciated
11-22-2011, 06:03 AM #7O U 8 1 2
- Nov 1999
- over here...
check the battery terminals for corrosion... also check to make sure you're not leaking power steering fluid on the alternator (our cars are imfamous for that)... i've got bad batches of new alternators before...
11-22-2011, 06:14 AM #8Junior Member
- Nov 2011
- Houston, TX
battery terminals are good .. Whats the power steering fluid on the alternator? Where is that located?
11-22-2011, 06:16 AM #9Junior Member
- Nov 2011
- Houston, TX
will that cause the alternator to burn up?
11-22-2011, 06:51 AM #10
11-22-2011, 07:19 AM #11Junior Member
- Nov 2011
- Houston, TX
ok thanks checked it seal is good and nothing is on the alternator. Its like the pcm isnt sending a signal to the alternator. What will cause this its a brand new pcm. And what should the volts read between the pcm to the alternator ?
11-23-2011, 10:06 AM #12Junior Member
- Apr 2010
- Virginia
Turns out I had a bad alternator. Put one on yesterday and car is running great
11-26-2011, 05:57 PM #13
11-28-2011, 05:55 AM #14Junior Member
- Nov 2011
- Houston, TX
ok I have fixed the PCM and the alternator. The red wire that goes to the alternator was actually broke inside the wire. Everyone who is having this problem check that damn red wire extremly well before taking it to the shop! Its about 30 dollar to fix. Thanks for all the help guys.
11-30-2011, 05:19 AM #15Junior Member
- Apr 2010
- Virginia
No I got a new one. No remanufactured parts on my SS!
11-30-2011, 06:18 AM #16Electrical Engineer
- Jul 2009
- North of the Motorcity
Smart man!
Originally Posted by adamz02ss:2723712
"Some people live for the rules..... I live for exceptions" N. Hexum
08-08-2012, 04:22 PM #17
i have a problem with it charges then it the meter goes way low then there is a click and it starts charging.. but then it randomly starts going down randomley.. i have gone thru all the checks lost!! any input would be great
TPS voltage
By 98TransAmWs-6 in forum General HelpReplies: 29Last Post: 04-26-2016, 09:51 PM -
Low Voltage, Why?
By Z28boy2000 in forum General HelpReplies: 32Last Post: 02-27-2014, 06:17 PM -
Low voltage
By Art99SS in forum General HelpReplies: 1Last Post: 06-02-2009, 04:34 PM -
voltage
By tingo99 in forum Internal EngineReplies: 5Last Post: 08-06-2008, 06:47 AM -
voltage problem
By firebirdlt4 in forum General HelpReplies: 3Last Post: 03-13-2008, 04:57 PM
