Results 1 to 10 of 10
Thread: Possible rear end build
03-11-2008, 05:23 PM #1
I have a friend that offered to help build a new rear. I wanted to do some research before actually asking his help and curious what all do you need to buy with a new rear.
I know that there's a moser 9 that supposedly is straight bolt on for f-bod's and from what I've heard it's pretty sweet. Can anyone help with what else I might need, so that I can price it with the wife. Don't know if there are any complete kits to be found or not.
If you know any place with a good deal I would greatly appreciate that info also.
Thanks,
03-12-2008, 02:18 PM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
I bought my 9" here http://stores.ebay.com/Quick-Performance-Racing Great guys and will beat anyones price. Been in business over 20 years and customer service was awesome. Just tell them what you want and they build it to your specifications
03-12-2008, 03:17 PM #3
Thanks for the link, I'll look through. I'm not honestly sure what all I want as I don't really understand the makeup of the rear. I like the 9 that was built for f-bods as I hear it really does bolt up. Also, switch the gears to 4:10's, but other than that I'm not sure.
03-15-2008, 07:23 AM #4
Oooh.... Does anyone know what the difference between 3 Channel and 4 Channel ABS?
http://www.strangeengineering.net/ne...earendAD1.htmlLast edited by chuckie669; 03-16-2008 at 04:06 PM.
03-16-2008, 05:55 PM #5Slow'er'Ass
- Thornton, CO
2 channel - No ABS or TCS
3 channel - ABS or TCS (only one)
4 channel - ABS and TCS
I like the 9"
Torque arm mount seems more reliable to me.
The D60 might be stronger, but not much to worry about with a 9". Several VERY fast cars using the 9".2008 Trailblazer SS
Lowered, HID's, tinted.
03-16-2008, 07:45 PM #6
Great, thanks Luos. Do the 6speeds have TCS? I know there's no button, but is there some form of it, or is a 3channel sufficient?
03-16-2008, 07:48 PM #7Slow'er'Ass
- Thornton, CO
If you don't have a button, your car doesn't have it.
03-16-2008, 07:50 PM #8
I figured I'd get down and dirty today and see what inside of the differential looks like. After popping the top I realized that there was really not much fluid in there. Also, saw bubbles (Dunno if thats normal or not). Other than that everything seemed in decent shape.
Got everything pulled sprayed some rust X on the case and painted it silver since I cannot put anything back on my car that's rusty. Used some red RTV Gasket maker and took her for a spin.
Saw a little dark spot underneath after my test drive which might be a leak but it was real dark and I'm hoping came from around one of the bolts.
Here's where I started
Bubbles WTF?
Rust Exterminator sprayed on
Followed by some high heat silver
Never used RTV so hopefully I put the gasket on properly
Finished and Filling her up.
03-17-2008, 05:28 PM #9Slow'er'Ass
- Thornton, CO
Did you enjoy that smell??
Hard to judge by looking at pictures.
Not sure about the bubbles. Probably a good thing you got the fluid swapped out.
Did you use the LSD additive and 2 quarts of fluid?
03-17-2008, 06:19 PM #10
Edit: Yeah the rotten eggs smell was great. My wife thought I farted, J/k.
The RP says it has limited slip additive. I heard that I need two qts but could only get 1 3/4 in before it started overflowing. Filled on level ground.
I checked this morning and there's a small dot of greasy funk around the bottom bolt. went after them with the wrench again and they could use the tightening.
My 8.8 Rear Build
By SMWS6TA in forum DrivetrainReplies: 239Last Post: 06-22-2018, 01:52 AM -
500CI Chevy LS1 Engine Build - How To Build A 500C
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 02-17-2009, 07:10 PM -
Rear alignment is off after Koni/!= rear isolator lowering, car pulls to right, specs
By anestech* in forum Suspension and HandlingReplies: 13Last Post: 07-08-2007, 09:42 AM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Randy's Rear End Shop Get's Punked (Prank) - Woman looking for a bigger rear!
By powermelissa in forum Multimedia SectionReplies: 0Last Post: 05-25-2007, 10:37 AM
