Results 1 to 11 of 11
Thread: whats needed for a 9 inch
03-10-2008, 04:57 PM #1
I was wondering what is absolutely necessary to do a 9 inch swap...I had a shop do it and ive been having issues with the rearend like noisy gears but he keeps saying I need this and that
03-10-2008, 05:03 PM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
You will need a conversion u-joint, 2ea 3" exhaust clamps to mount the sway bar, your old Brake Backing plates from your 10 bolt. Not too bad of a install but you will need to "pound" the sheetmetal up around where your torque arm mounts for the torque arm to clear.
I would recomend Motive Performance gears. They are strong and Quiet.2000 SS Camaro Heads, Large cam, Fast 90, 9"w/430's and locker, yada yada yada... you get the picture
03-10-2008, 06:48 PM #3
My cars has been whining on the highway pretty damn loud and the guy keeps saying its because of the stock u joint but I thought the stock u joint and torque arm would only cause vibrations not whine...also the sway bar is hitting the differential a slight bit
he says i need to change the torque arm also and sway bar
03-11-2008, 08:35 PM #4
03-11-2008, 09:19 PM #5Impounded
- Oct 2007
- Beaver Dam KY
Its your gears not your u-joint that is whining. Ujoints usally clunk and smack.. in my case that is..
BUMP for more help btw
03-12-2008, 11:58 AM #6
yea I was telling him that its the gears that are whining not the u joint!!i hope he takes car of it because im going to be picking her up today...
plus have any of you guys has issues with sway bar clearence also?Last edited by JattGunMan; 03-12-2008 at 03:01 PM.
03-12-2008, 12:00 PM #7Slow'er'Ass
- Thornton, CO
$2500
03-12-2008, 03:02 PM #8
I already payed the 2500 plus install and what not but the guy doesnt want to fix the gear whine...should I buy a u joint and then maybe hell fix it
03-12-2008, 05:11 PM #9Slow'er'Ass
- Thornton, CO
How bad is the whine?
Any suspension pieces as well??
03-12-2008, 05:15 PM #10
well the whine is louder than my exhaust cutout ,veryy annoying...no suspension parts..
03-13-2008, 09:13 AM #11Slow'er'Ass
- Thornton, CO
Lowered?
Or stock height?
Where did you buy the rear from?
So whats needed in a cam install?
By 95camaroZNC in forum General HelpReplies: 1Last Post: 02-04-2010, 11:22 PM -
Whats needed for 383 Stroker Swap?
By Patsy57 in forum Firebird / WS6Replies: 11Last Post: 03-26-2008, 05:50 PM -
whats needed for a t56 upgrade
By Qwk94Z28 in forum Manual TransmissionReplies: 0Last Post: 01-07-2008, 08:47 AM -
Whats needed for 7k redline?
By stevegrizzle in forum Internal EngineReplies: 15Last Post: 06-24-2007, 09:36 PM -
whats the widest tire i can fit on a 8 inch rim?
By 98tadriver in forum Wheels and TiresReplies: 2Last Post: 12-16-2005, 11:24 AM
