Results 1 to 16 of 16
Thread: Whats needed for 7k redline?
06-22-2007, 07:42 AM #1
I am going to do h/c soon and I want to have a car that I can cruise around at sub 2000 rpms, still get like almost 20/30mpg, and that redlines at 7k instead of 6k. Also I want to be over 400/400. What do you guys suggest?
06-22-2007, 11:19 AM #2
Im not saying im dead set on that but those are my goals, ......little help?
06-22-2007, 11:30 AM #3Slow'er'Ass
- Thornton, CO
Why do you feel the need to spin it so high?
Also...the stock bottom end won't like that kind of RPM.
06-22-2007, 12:16 PM #4
Where did you hear that about teh stock bottom end?
I don't have to have it that high, but I think that with the right cam/ head combo that there would be a lot of power to utilize up there at 7k. maybe 6500 is a more reasonable goal?
06-22-2007, 12:32 PM #5
06-22-2007, 10:22 PM #6Member
- Jul 2006
- Glen Carbon, IL
Silver- 2000 Camaro SS
The stock rods and pistons will be ok with good rod bolts, but for how long is the ? ARP rod bolts, forged pistons/rods balanced could see 7500 safely.
06-22-2007, 10:47 PM #7
I'm cammed with 918 valve spring's and I'm capable at sustaining 6,800 RPM's as is but with pushrods and possibly valves, it should hold 7,000 RPM's. The thing is though there's not alot of reason to be that high because of the power curve though, unless your wanting to be able to shift directly into the middle of the powerband for third and fourth. The cool thing about it though is I can chirp the tires shifting at 115 because it sets me right into the powerband.
06-23-2007, 07:11 PM #8
Thanks for the info guys, any other setups?
Yeah I like the idea of being right in the powerband..........any dyno graphs so I can see what you guys are talking about as far the #'s falling off on top end.
06-24-2007, 07:27 AM #9Member
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
My car never stops making more power all the way up to 6600, thats the highest i wanted to spin it on the dyno so i'm not sure when it would flatten out.
And if you want to stay in the powerband a gear change would help do that.
06-24-2007, 08:34 AM #10
here you go. 400 rwhp and the graph starts falling off after 6300 rpms
http://vincihighperformance.com/BECK...CT%20PAGE.HTMLCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
06-24-2007, 10:03 AM #11
I see.......
What is the deal with the hand held tuners, are they custom tunes?Last edited by stevegrizzle; 06-24-2007 at 10:15 AM.
06-24-2007, 02:19 PM #12
06-24-2007, 04:43 PM #13Member
- Feb 2007
- Bakersfield, CA
Well like i said my car did not fall off at 6300 with the 228/228 .588/.588 114 cam i have installed and i'm making a little over 400 RWHP.
06-24-2007, 09:32 PM #14
06-24-2007, 09:33 PM #15
06-24-2007, 09:36 PM #16
yes, they used their very own designed handheld. while you don't get complete control over everything with a handheld, there are a few out there that do pretty well. i used to have the vinci tuner. used it to tune the wife's car when it had heads and cam. here's a writeup i did on it
http://www.stealthram.com/vhptuner.htm
So whats needed in a cam install?
By 95camaroZNC in forum General HelpReplies: 1Last Post: 02-04-2010, 11:22 PM -
Whats needed when changing clutch
By caveblazin in forum Manual TransmissionReplies: 14Last Post: 10-08-2008, 10:35 AM -
Whats needed for 383 Stroker Swap?
By Patsy57 in forum Firebird / WS6Replies: 11Last Post: 03-26-2008, 05:50 PM -
whats needed for a 9 inch
By JattGunMan in forum DrivetrainReplies: 10Last Post: 03-13-2008, 09:13 AM -
whats needed for a t56 upgrade
By Qwk94Z28 in forum Manual TransmissionReplies: 0Last Post: 01-07-2008, 08:47 AM
