Thread: Car has sat for three years.
03-10-2008, 01:18 PM #1
What am i looking at? My buddy got deployed a while ago and the fuel pump went out on his 1995 lt1 so it has sat in his garage for 3 years and now he wants to sell.
I am thinking fuel filter, fuel pump, new gas, new battery, new fluids/oils, seafoam, fuel system cleaner, and a good cleaning? Any other serious issues i am getting into that i dont know about? I know he is not covering something up like a bad motor/trans.
Like could the injectors be clogged and need to be replaced or the water pump frozen up because of the dexcool, or fouled plugs? Is there any damage in starting it the way it is or will there be any dry start problems?
03-10-2008, 01:36 PM #2
i wouldn't start it until you at least change the oil, fuel, fuel filter etc.
but def do all the stuff you listed right away - you will have to change the FP anyway before it will start too so might as well do all the items before you even attempt to start it.
03-10-2008, 01:46 PM #3
I would also turn it over by hand a few times before trying to start it. I would also prime the oil system before starting it but that's just me. I'd drain that gas out completely if you can. I probably wouldn't change the fuel filter until you've started it so all the crap that's settled in the tank doesn't just mess up a new filter. After you run it once or twice then I'd change the fuel filter.
03-10-2008, 05:09 PM #4
03-11-2008, 11:01 AM #5
Anything else? I am going to check the tries but is there any other concerns?
Only 18 more years
By Mr. Luos in forum Almost Anything GoesReplies: 6Last Post: 09-04-2011, 06:49 PM -
25 Years Ago
By Cmdr Zero in forum Almost Anything GoesReplies: 22Last Post: 02-01-2011, 07:29 AM -
Anybody 30 years old....
By Sarge in forum Almost Anything GoesReplies: 41Last Post: 09-04-2009, 04:36 PM -
Well after 30 years
By Sarge in forum Almost Anything GoesReplies: 53Last Post: 08-21-2009, 11:40 AM -
New Years Eve.
By Danger731 in forum Western MembersReplies: 1Last Post: 11-13-2006, 06:18 PM
