Results 1 to 1 of 1
03-09-2008, 10:19 AM #1BAD INFLUENCE
- Sep 2005
- aston,pa 19014
black- 1998 pontiac trans am
links of my 98 ta ,new engine and paint
C:\Documents and Settings\Suzy\My Documents\My Pictures\2008_03_08
_
C:\Documents and Settings\Suzy\My Documents\My Pictures\2006_08_11
here is my 98 trans am w / 40 k miles , im the original owner, first link is the new paint job , the car is dirty,been sitting all winter,second is the new completely built top and bottom ls1 , scat crank & rods,mahle pistons,comp push rods,lifters,and shaft mount rockers, on patriot 2.05/1.60./59 cc heads, hooker super comps,into the off road pipe,into the cat back borla , as you can see I put the spec stage 3 on it , took it to englishtown 1 time , 3 passes , and the clutch blew, the setup only has 3k on it ? something must of happened on the install . the car was tuned by rpm performance in delaware with the ls1 edit . I have to get the rear, suspension,and im gonna hit it with some spray , and I should be pretty happy!
Help with Disassembly to Paint Engine Parts
By smitty504 in forum Appearance SectionReplies: 6Last Post: 10-02-2012, 04:43 PM -
What Color to Paint Engine Block
By ls1camino in forum Appearance SectionReplies: 2Last Post: 10-05-2010, 07:05 AM -
Paint engine Bay
By blk_jaws in forum Appearance SectionReplies: 1Last Post: 06-09-2009, 12:25 PM -
By mad3125 in forum Eastern MembersReplies: 3Last Post: 03-09-2008, 01:34 PM -
Engine Paint Decision
By 98Camarod in forum Appearance SectionReplies: 7Last Post: 12-12-2006, 12:43 PM
