10-01-2012, 07:56 PM #1Junior Member
- Sep 2012
- IA
Black- 2002 Camaro SS
Help with Disassembly to Paint Engine Parts
At the end of this month I am taking my valve covers off to paint wrinkle black and paint my coil brackets red. I have never removed my valve covers and I looked for a sticky in multiple different sections but couldn't find anything. Can someone help me out with some instructions or if there is a sticky out there somewhere post it up.
Also, how do you remove the SLP lid? Do you just remove the MAF sensor with it? I am painting my lid and the base too. With the base do you remove this for paint too?
Sorry for the elementary questions but I just haven't done these things before but need to put some finishing touches on the engine bay.
10-02-2012, 08:01 AM #2Junior Member
- Sep 2012
- IA
no one? I know you obviously take the 4 bolts out of the valve cover but just looking for any other hints or tips, and the LID removal?
10-02-2012, 09:07 AM #3Senior Member
- Apr 2010
- Alabama
What year is your car, I am guessing it is a 99 and up? If it is a 99 and up you just take the bolts down the center out so you can move them up and down. They are held in by seals so you won't be able to take them out until the valve covers are off. Otherwise you just take all of the bolts off all around the valve covers.
The lid you unclip the clips, loosen the clamps on the bellows between the MAF and throttle body, disconnect the MAF sensor from the wire harness, lift it off the car and pull the bellows off of the MAF. Next take a hair dryer and heat up the neck of the lid, the MAF should slide right out. The base has 4 bolts I think that bolt it to the car, remove those and it lifts off.Last edited by 98TransAmWs-6; 10-02-2012 at 10:59 AM.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-02-2012, 12:53 PM #4Junior Member
- Sep 2012
- IA
10-02-2012, 04:44 PM #5Senior Member
- Apr 2010
- Alabama
Be sure to replace the gasket before you put them back on.
10-02-2012, 05:40 PM #6Junior Member
- Sep 2012
- IA
Yeah I will replace the gaskets, is there a certain brand or kind thats better than another?
10-02-2012, 05:43 PM #7
A Little Help with Disassembly and Painting
By smitty504 in forum Appearance SectionReplies: 4Last Post: 10-06-2012, 06:12 AM -
Paint engine Bay
By blk_jaws in forum Appearance SectionReplies: 1Last Post: 06-09-2009, 01:25 PM -
Question: How to paint engine bay plastic parts ?
By 98Z28importslayer in forum Appearance SectionReplies: 1Last Post: 07-10-2008, 12:55 AM -
links of my 98 ta ,new engine and paint
By mad3125 in forum Member's RidesReplies: 0Last Post: 03-09-2008, 11:19 AM -
What kind of paint for these parts?
By xinthenight in forum Showcar and DetailingReplies: 1Last Post: 08-18-2007, 02:04 PM
