    Member slikws6's Avatar
    Feb 2008
    southeast
    1998 WS6 Convert
    Convertible air leaking around window
    I have a convertible that at the back longest point of the drivers window leaks air and you can see a little gap.The weatherstriping is in great shape but looks to be a little futher in than the other side.How is the strip attached and can you move it without tearing it?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    You can't move it. Is the door in alignment? After time it could have sagged slightly. The window also has some adjustments. Do you close your door by the window?
    Feb 2008
    southeast
    1998 WS6 Convert
    Thanks bigron,
    No I do not close by the window.
    The doors close perfect.I was looking yesterday when I had the top down and behind the rubber is an aluminum rail that holds the rubber in place.It was bent in slightly towards the inside compared to the passanger side.I bent it a little but was scared it would break.This did help some and I am going to try to bend it a little more.
    I had to replace a broken window stabilizer a couple of weeks ago.I think maybe the window slamming into that rubber maybe bent the rail.
    Thanks
    Feb 2006
    Orange County, NY
    always dirty
    That could be it. Maybe the stabilizer is pushing the window out to far also.
  1. Replies: 3
    Last Post: 03-08-2017, 09:00 PM
  2. Convertible Rear Window Adhesive
    By kheflw in forum Convertible
    Last Post: 10-12-2013, 08:28 PM
  3. convertible window leak
    By 35th02Z28 in forum General Help
    Last Post: 09-16-2009, 12:22 PM
  4. convertible window replacement?
    By that1guy_21 in forum Convertible
    Last Post: 02-27-2008, 04:49 PM
  5. back window leaking
    By BLACKM6 in forum Convertible
    Last Post: 02-21-2008, 01:07 PM
