    Member 35th02Z28's Avatar
    Grand Prairie, Texas
    Onyx Black
    2002 Camaro Vert Z28
    convertible window leak
    I was wondering how common this happens with convertible F-bodys mine seems to be getting worse. I've gone up to the nearest chevy dealership and they wanted $1100 to fix one side. Also the other side has started leaking a little to, if I was to fix this do I just need the rubber seals or do I need to get a new retainer too, that holds the seals??
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    The driver or passenger side? There is some adjustment on the window regulator to help. Do all the gaps on the door and mouldings line up? Could be a sagging door. The seals might just be glued in place.
    Onyx Black
    Quote Originally Posted by bigrondownhiller View Post
    well on the driver window its where the center seal meets the windshield seal and at the back of the center seal where it meats that back seal and idk about the passenger side but it leaks almost the same. A while back we had a chevy dealership took a look at it only the driver side was leaking and they said they could adjust it to stop leaking but it had shrunk a lot so it would only last till I put the top down.
    Feb 2006
    Orange County, NY
    always dirty
    Well then you might have to replace it. Have you tried the dealer to see if you can get just that one piece? I am not sure if anyone is making them aftermarket yet.
    Onyx Black
    well I was looking at it last night and all of the seals look pretty worn on both side
  1. Window air leak 98 TA
    By JayTA98 in forum General Help
    Last Post: 10-29-2009, 02:39 AM
  2. Major window air leak.
    By Sarge91 in forum General Help
    Last Post: 03-02-2009, 08:29 AM
  3. Convertible air leaking around window
    By slikws6 in forum Convertible
    Last Post: 03-06-2008, 10:01 AM
  4. convertible window replacement?
    By that1guy_21 in forum Convertible
    Last Post: 02-27-2008, 04:49 PM
  5. ttop leak, hatch leak, and window motor problems
    By ATCharming in forum General Help
    Last Post: 07-23-2007, 02:30 AM
