Results 1 to 15 of 15
Thread: octane question
    Fresno Ca
    LPM
    2002 Z28 Camaro
    octane question
    When changing up in octane any things I should replace or do? Any info is appreciated. Thanks.
    are you talking about going from 87 to 93 or something? Or race gas?
    Fresno Ca
    LPM
    2002 Z28 Camaro
    yeah 87 to 93
    12-13-10 I was there
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    yeah 87 to 93
    Only thing I would do is reset the PCM by disconnecting the battery for about 20 minutes. That was the computer can re-learn its parameters based on the higher octane fuel. There is nothing you can physically do to adjust it though, its all done automatically in the PCM.
    Member totalkos's Avatar
    New Orleans
    Nbm
    why would you put 87 in something anyway? especially a z28, dont they require 91 and up? i know mustangs say 89
    Senior Member
    TN
    2016 Dodge Challenger
    Wont the computer learn on its own? It will take a tank or two before anythng is realized. By running better gas you"ll get you get less knock, if there was any, Which doesnt that equate to more timing and thus more power?
    Tulsa,OK
    Quick Silver
    2002 Z06
    According to the owners manual you should run 91 or the highest octane available.
    The computer will learn on its own but unless you just don't like re-programming the radio a battery disconnect like said above is probably the best route to go so the computer is not playing with the timing and Air Fuel ratio, probably isn't the best for Plug life.
    Put some high octane in that baby, it will like it.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Dirty Harry hec33's Avatar
    Starkville, MS
    1999 Z28 M6
    It says you can run whatever in the manual, but it says for best performance use premium... The computer just learns if it senses a knock
    Georgia
    2014 Camaro 1LS
    nothing but 93 here
    Springfield
    2004 SVT Cobra
    For the most part in my car i run 91 octane because thats whats widely available around here. Every now and then i put in a tank of 93 and seems to me like im losing a slight bit of performance by doing this. Could this be because im not giving the computer enough time to calibrate for the 93?
    Starkville, MS
    1999 Z28 M6
    Quote Originally Posted by drummer52910 View Post
    You should see no change, or barely any performance gain from doing that... It definately should not lose any power, unless it is bad gas.
    Theoretically, it should reduce the chance of detonation which would let the car run more timing, and give you more power. Without any timing change, there will be absolutely no change in horsepower whether you use 91 to 120 octane... But there should not be any performance lost at all
    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    nothing but 93 here
    you know that gas in our area is actually better than the rating. our 87 if tested would come out to 91. and our 89 comes out to 92. the 93 comes out to 95.something. I read a little about how the ethanol they are putting in it now in our area raises the octane of it significantly, but they can't rate it higher because of some regulation that says they have to base it off the gas itself not the ethanol added to it. so if you wanna runn 89 in our area it's completely fine. I normally run 93 if I think I might go to the strip, but 89 almost all the other times to save a little cash.
    Starkville, MS
    1999 Z28 M6
    Quote Originally Posted by jimmybling31 View Post
    Yea, I saw Etahnol enhanced fuel, or whatever you call it, when I went to Atlanta for spring break. We don't have the privelege of that here yet. Here, if you put anything under 93, you run the chance of water in your tank.
    hixson tennessee
    94 camaro z28
    Quote Originally Posted by hec33 View Post
    eh. I have run 89 for a while no problems. I'm not too scared. i had to run premium in my last car, so being even able to run lower is nice to me. lol
    Starkville, MS
    1999 Z28 M6
    Lucky you...
  1. Octane question
    By CrazyCalvinWilliams in forum Internal Engine
    Last Post: 05-17-2016, 08:02 PM
  2. octane ?
    By barryTA in forum General Help
    Last Post: 01-28-2008, 05:55 PM
  3. octane
    By gagoat in forum GTO
    Last Post: 09-20-2007, 10:16 PM
  4. 93 Octane question
    By blackhawk01 in forum Firebird / WS6
    Last Post: 08-03-2007, 08:38 PM
  5. 91 octane VS. 91 octane without ethanol
    By Mr. Luos in forum Rocky Mountain Members
    Last Post: 04-07-2007, 05:02 PM
