Results 1 to 11 of 11
Thread: octane
09-19-2007, 06:08 AM #1
octane
What is the max octane the ls1 can handle
09-19-2007, 09:29 PM #2
09-19-2007, 09:37 PM #3
93 105 110 120 ?????????????????????????
anybodyLast edited by gagoat; 09-19-2007 at 09:53 PM. Reason: no responce
09-19-2007, 09:52 PM #4
09-20-2007, 02:46 PM #5doesn'tplaywellwithothers
- Jan 2007
- Mayberry....(Indiana)
Black- 2004 GTO
I think the reason NO one has answered your question is because of your wording. According to GM specs, LS1 engines require premium octane, which is 91+. I run 93+ in my car and always have; although, I have to now that it is supercharged. If you use a lesser octane you run the risk of spark knock. 91+ or greater is what I would use in your car. Hope this helps. Brad
'04 gto M6 slp ceramic coated headers,B&m sport shifter,harrop cover,3.5"aluminum BMR driveshaft, BMR axle stubs, BMR Half shafts, BMR SFC's, loudmouth2 exaust,90mm FAST T/B,Magancharger(high helix upgrade)......other misc. suspension,Cross drilled, slotted rotors. Meth Kit, spraying @ 3psi and up
09-20-2007, 03:43 PM #6I went to Playboy Mansion
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
I think he is wondering about race fuel.
09-20-2007, 03:46 PM #7
my friend runs 110 or 117 at the track but he has no cats....he has an 02 WS6
09-20-2007, 09:14 PM #8
The biggest reason No one has answered is due to the ?.
The motor can handle 120 octane if you want to waste the money as long as it is lead free.
Leaded race fuel which MOST blends are will kill factory style 02 sensors quick!
Your motor will NOT need anything beyond the 91 or 93 pump octane you get at the gas station unless you have added cylinder pressure. Add even then depending on the timing settings and how much pressure you've added you can still get away with pump gas safely.
Here is an link or two that might help aid you in some knowledge on this matter.....
Your friend is wasting his money if that WS6 is anywhere near stock!
We have found that you actually loose power if you put way to high of octane due to the slower burn rate it does NOT keep flame travel optimized.
http://www.wanderings.net/notebook/M...sWorthTheMoney
http://www.wisegeek.com/what-is-high-octane-fuel.htmDon't be afraid of the bottle!!! Be afraid of your tune!!!
09-20-2007, 09:52 PM #9
09-20-2007, 09:56 PM #10
All octane is is the measure of a fuel's re;uctance to ignite. Higher octane means that the fuel needs more heat/pressure to ignite. This is why it is funny to hear people that have low power cars that are filling with super say that they think they are getting more power. The fact of the matter is that the lower the octane, the biggerthe explosion. This is why boosted/high compression cars need higher octane to combat the problem of detonation. Octane is actually a really interesting subject when you get to know what it means and what it does. Most people think that it is cleaner or some how adds power when that is not even remotely true in your avergage street car.
09-20-2007, 10:16 PM #11
no 93 octane
By joejenkinsglass in forum Firebird / WS6Replies: 75Last Post: 04-17-2011, 12:01 AM -
octane ?
By barryTA in forum General HelpReplies: 7Last Post: 01-28-2008, 05:55 PM -
n2o and octane
By pocheasy in forum NitrousReplies: 8Last Post: 12-10-2007, 07:19 PM -
What is the Best Octane?
By 1TA LS1 in forum Firebird / WS6Replies: 36Last Post: 05-18-2007, 08:00 PM -
91 octane VS. 91 octane without ethanol
By Mr. Luos in forum Rocky Mountain MembersReplies: 29Last Post: 04-07-2007, 05:02 PM
