Results 1 to 10 of 10
03-03-2008, 04:17 PM #1Member
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
Adjusting how much my headlight closes
My passenger headlight cover closes all the way flush with the car and doesn't keep a small gap in between like the driver side does. I was wondering if anyone could tell me how to adjust it so it doesn't shut all the way against the car.
Thanks
03-04-2008, 05:09 PM #2Junior Member
- Feb 2008
- NC
if you look behind the bucket with the hood up and the light down you will see a white nut. Take a 10 MM wrench and turn it counterclockwise until the desired height is reached
03-04-2008, 05:54 PM #3Member
- Tulsa,OK
Quick Silver- 2002 Z06
Pretty simple. Be ready to mess with it. Last time I played with mine I was out there turning that nut for about an hour until my anal self got it right
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
03-05-2008, 03:41 AM #4Member
- Feb 2007
- Bakersfield, CA
ok thanks guys
10-21-2010, 05:53 PM #5Junior Member
- Sep 2010
- L.A.
Black- 00 Firebird TA WS6
Would this work for the Headlight UP? Reason being, I just installed HID Lows and Fogs thinking these will really light up the road way better then the stocker's. Well, they do improve the road, and REALLY are bright if your standing in front of the car.
I've tried and tried to adjust them and with the Torx wrench and can't seem to get them to LIGHT THE ROAD correctly. They are bright enough. It seems that the Bezel is partially blocking the light and or the buckets are just too high.
I have HID in 3 other cars and they all blast the road with good light, but Not the TA. Any suggestions would be fantastic!
10-21-2010, 07:16 PM #6
10-22-2010, 03:21 PM #7Member
- Tulsa,OK
Yes down lower there are nuts that control where the motor stops.
I've had the same issues with our T/A after I upgraded the lights to HID. Still have not gotten it to a point that I"m happy with.
I've decided it needs to be put on a machine and hopefully a shop with one can get it just right.
10-24-2010, 07:16 AM #8Junior Member
- Sep 2010
- L.A.
Thanks for the reply....The Down stop should help, but (By Nature of the design, There isn't too much that can be done with getting them to shine more towards the Center)....Unless I make some type of spacer to bring the lights away from the housing, which is kinda of Mickey Mouse, or switch the Low and High beam locations, which just wouldn't look good, plus would probably catch the eye (even more then normal) of the Cops....
Thanks to all......Maybe I'll post this Specific question in the main forum.
10-25-2010, 07:53 PM #9Junior Member
- Sep 2010
- L.A.
How do you adjust the <stop> for the Up light....It seams like it has no adjustment, just a solid stop connected to on of the assembly nuts, if I'm seeing it correctly...Basically, I see no adjustment, just a soild stop?
ThanksLast edited by yellowlighting; 10-28-2010 at 05:08 PM.
10-27-2010, 09:42 PM #10
Sorry to bump this old as fuck thread, but can i get a picture of this white nut on the back of the headlights?
adjusting headlight so it don't scrape bumper?
By knightryda01 in forum Appearance SectionReplies: 7Last Post: 10-12-2013, 05:31 AM -
Question: Headlight help....bad fit or needs adjusting?
By FinZ28 in forum General HelpReplies: 7Last Post: 02-07-2012, 08:58 AM -
Question: Headlight 'Adjusting' Tricks 98-02 TA
By yellowlighting in forum Firebird / WS6Replies: 4Last Post: 10-25-2010, 07:55 PM -
Adjusting headlight?
By silverWS6 in forum Firebird / WS6Replies: 11Last Post: 06-04-2010, 06:43 PM -
R/H headlight noise after it opens/closes
By 19691998firebirdtransam in forum Stereo and ElectronicsReplies: 11Last Post: 12-03-2005, 03:22 AM
