    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Adjusting headlight?
    How can i adjust my headlights? After the body shop fixed my car they seem to point down more and i would like to move them up a little so i could see farther without using my high beams
    Member Transambroli's Avatar
    Ft Washington MD
    arctic white
    99 Trans am
    I just aimed mine down this weekend. Manually raise the light take the black piece off the surrounds the lights as you would if you were replacing a bulb. Get the torx screwdriver you use to take the housings out there will be I think one torx screw on the side and one on top in the center; use those to adjust the lights. The top one aims them up and down.
    phoenix
    04 2500 4x4 crew cab
    Why would you manually raise them? Turn them on at night, and put a towel over one side. Aim the first side, then switch the towel to the other side. Piece of cake. You don't have to remove any plastic bezels. Just turn the screws (torx T-15). I actually keep that bit in my car at all times. They get rattled, or you get flashed too much, one turn is usually enough to bring them down a bit. This is for when you have the car loaded. Extra passengers,etc.
    Try roasting your crow. It'll be easier to get down.
    I like grilling mine with a nice brown sugar based rub
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Sweet! Ill try this tomorrow night! One of my headlights actually went out right now
    phoenix
    then you need to remove the plastic bezel, and the metal frame theat holds the bulb in place. pretty easy.
    Apr 2010
    Alpharetta, Ga
    04 Cobra 'vert - M6 mysti
    02 WS6 coupe - A4 red
    Make sure that the power cable to that headlight didn't come loose. I went to replace a lamp that I thought was bad, only to discover the power cable had come loose. It had caught on an interior corner and pulled loose when the headlight raised/lowered. Especially since it was just in the shop, a cable mighta been pulled loose or not reconnected tightly...
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Quote Originally Posted by Schmalgar View Post
    Good point, i did replace my headlight gear like 2 dyas ago.
    *ninja edit. But then if the cable was loose then my light wouldn't go up or down right?
    Apr 2010
    Alpharetta, Ga
    Nah, there's the power to the motor and the power to the lamp, they are different. The power to the lamp is more loosely situated...
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Well i didnt bother to check it today and i got a warning for no headlight
    Apr 2010
    Alpharetta, Ga
    doh!
    At least he was in a good enough mood to just give a warning. All the cities in my area are broke, so they give tickets for every offense. One city was just in the local news, being rebuked by the state for using traffic citations as blatant revenue generation...
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Yup it was the damn power cable behind it
    Apr 2010
    Alpharetta, Ga
    Sweet! I actually have useful knowledge to share! Woo hoo!
  1. adjusting headlight so it don't scrape bumper?
    By knightryda01 in forum Appearance Section
    Last Post: 10-12-2013, 05:31 AM
  2. Question: Headlight help....bad fit or needs adjusting?
    By FinZ28 in forum General Help
    Last Post: 02-07-2012, 08:58 AM
  3. Adjusting how much my headlight closes
    By sfletch2000 in forum Firebird / WS6
    Last Post: 10-27-2010, 09:42 PM
  4. Question: Headlight 'Adjusting' Tricks 98-02 TA
    By yellowlighting in forum Firebird / WS6
    Last Post: 10-25-2010, 07:55 PM
  5. TM adjusting 07 z06
    By extanker in forum Corvette
    Last Post: 05-12-2008, 04:25 PM
