Results 1 to 2 of 2
Thread: recharging a/c
    Decatur, IL
    Blue
    2001 Trans AM
    recharging a/c
    my a/c compressor wouldnt kick on so i jumped the low pressure switch and it came on. So i assume i need to charge up the system. has Anyone done this themselves? i know they sell kits at the automotive stores, or should i take it to a shop.
    Member Nitrous's Avatar
    Houston
    97 GMC with 02 LS6 engine
    Look at the pressures and adjust accordingly. That's a good check but I wouldn't fill the system until I saw the running pressures. Based on ambient temperatures say 70-80 degrees you should be anywhere from 16-29psi on the low side and 115-200 on the high side. The pressures will increase with temperature so say at 80-90 degress you should be anywhere from 19-39psi on the low side and 140-235 on the high side.
    Hope this helps.
  1. recharging ac system
    By carnutt in forum External Engine
    Last Post: 08-03-2006, 02:45 PM
  2. AC Recharging
    By AU98TA in forum General Help
    Last Post: 06-11-2006, 10:40 AM
