Thread: recharging ac system
07-30-2006, 01:16 PM #1
- Dec 2005
- NJ
red- 2000 camaro
i tried to charge my ac today.I bought the bottle with the gauge now when i went to hook up the gauge on the low side.the low side has the bigger fitting and the high side has the smaller fitting.Does anybody know how to charge the ac in thier camaro?.Is there an adapter fitting?On my impala the small fitting is on the low side and correct me if Im wrong the high side on the camaro is on the tank and the low side fitting is right by the radiator.
Thanks for your help
07-30-2006, 01:26 PM #2
- Aug 1999
- No Where
I am pretty sure the low side is on the tank. That is where I filled mine.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
07-30-2006, 03:02 PM #3
- Dec 2005
- NJ
red- 2000 camaro
the low pressure switch is inline with the fitting that not on the tank.Im pretty sure the fitting on the tank is the high side.When i tried putting it through the one on the tank .I felt the can swell up and i stopped filling it .
07-30-2006, 03:09 PM #4
i know my buddy blew his pump and spent $1000 to save $40
07-31-2006, 10:05 AM #5
the low side is on the tank.. the high side is the one that runs right to the left of your radiator.. to fill.. turn the car off and put the hose on to do this pull back the sleve and push on the fitting.. then snap the sleve shut.. make sure it is on tight.. then turn on on the car turn your ac on max ac and turn the fan all the way up.. turn the bottle upside down and let it drain.. should take between 2 and 5 mintues to drain the can.. just make sure that you have your ac system empty before filling it.. to do this open your high pressure side (this is the time you put on some eye protection) take a small flat head screw driver and push in the valve inside there and SLOWLY release the pressure.. be sure to be gentle on the valve stem.. you break it and your gonna have to spend some money... if you want to avoid all this hassle.. just take it in to get vaccumed out and new r134 put in it's like 100 bucks tops.. but hey.. it's done right and your ac will be really cold
98 Z28, flowmaster catback, kn filter, FRA, TB bypass,160 thermostat, ngk tr55's, sumitomos. more to come
07-31-2006, 06:42 PM #6
- Jul 2006
- Collinsville, Il
White- 1986 Camaro
If your system has lost all of its charge, it really should be vacuum pumped down. This removes all the moisture from the system and allows for the coldest possible air and greatest reliability.
08-03-2006, 02:45 PM #7
Ram Air system?
By AB'sLs1 in forum External EngineReplies: 47Last Post: 05-25-2009, 08:27 PM -
recharging a/c
By a338566 in forum GM TrucksReplies: 1Last Post: 03-02-2008, 05:55 PM -
Nos Nitrous System #05177-nos 98-02 Ls1 Dry System
By KIXASS in forum Parts For Sale / TradeReplies: 0Last Post: 08-01-2007, 09:56 AM -
Is this an OK system?
By Lower in forum Stereo and ElectronicsReplies: 0Last Post: 07-06-2007, 02:42 PM -
AC Recharging
By AU98TA in forum General HelpReplies: 5Last Post: 06-11-2006, 10:40 AM
