Results 1 to 20 of 31
03-02-2008, 02:37 PM #1Awaiting Activation
- Aug 2007
- odessa,texas
69 hugger orange- 98 z28
oh no ,its time to upgrade some shit
so i killed my car at the track the other night
its making a loud popping noise that sounds like its coming from the rear axle
i changed the u joints checked the rear end gears and changed the fluid everything seemed to be in good order
it only makes the popping noise at higher rpms and when your coming to a stop or slowing down
i dont think i broke an axle or it would make noise all the time plus i drove it home it is definitely something that is rotating clutch maybe?
any ideas would be great im done tearing in to it for this weekend and need some fresh ideas
03-06-2008, 06:30 AM #2
Have you checked the wheel bearings?
03-06-2008, 11:01 AM #3
sounds like bearings, mine did about the same thing
03-06-2008, 12:13 PM #4
mine did the same thing! remember to check your axels for scaring... if they are scared... then you better think about new axels..
03-06-2008, 01:44 PM #5
03-06-2008, 01:55 PM #6Awaiting Activation
- Aug 2007
- odessa,texas
Yeah I Was Going To Check The Bearings Next
03-09-2008, 05:08 PM #7
did you put the limited slip additive in when you did the fluid change?
03-10-2008, 05:21 AM #8Awaiting Activation
- Aug 2007
- odessa,texas
03-10-2008, 08:42 AM #9
03-11-2008, 05:47 AM #10Awaiting Activation
- Aug 2007
- odessa,texas
Its Not The U Joints ,its Not The Wheel Bearings, And Its Not The Rear End Fluid
But It Is Damn Sure Still Popping Any More Ideas Anyone
Im Thinking Its Got To Be A Bent Driveline Or Something Now
03-11-2008, 06:26 AM #11
Crawl underneath the car and push up on the transmission and chech the tranny mount. Mine went bad and the transmission would slam the underbody sounding like a popping noise.
03-11-2008, 06:48 AM #12Awaiting Activation
- Aug 2007
- odessa,texas
03-11-2008, 06:53 AM #13
Can you put the car on jack stands and run it through the gears and hear the noise? Or does it have to have a load on it to pop?
03-11-2008, 07:00 AM #14Awaiting Activation
- Aug 2007
- odessa,texas
03-11-2008, 07:09 AM #15
I don't know man, Sounds like something you need to get a buddy help you find. Unless you can get a video of the noise I think were out of suggestions.
03-11-2008, 08:07 AM #16Awaiting Activation
- Aug 2007
- odessa,texas
03-11-2008, 08:19 AM #17
LOL!!! I guess drive it till something goes BANG!! Then you will know
03-11-2008, 08:55 AM #18
03-11-2008, 11:24 AM #19Junior Member
- Sep 2007
- I sleep in the house...Live in the shop
midnight Blue- '99 Trans Am ws7
U joint? i had same issue with my t/a turned out to be a fricken u joint i dont rememeber if it was the one on the front or back of the driveshaft...replace tehm both once
03-11-2008, 02:32 PM #20Awaiting Activation
- Aug 2007
- odessa,texas
Time for a brake upgrade
By pajeff02 in forum General HelpReplies: 52Last Post: 03-17-2012, 02:05 PM -
Tax Refund...Time to upgrade!!!!
By 5.7literMustangEater in forum GTOReplies: 23Last Post: 03-07-2009, 03:18 PM -
Time to upgrade the TV.
By Cerwin Vega Fan in forum Almost Anything GoesReplies: 56Last Post: 04-17-2008, 06:43 PM -
when is time to upgrade valvetrain?
By greatwhiteZ28 in forum Internal EngineReplies: 5Last Post: 09-06-2007, 05:05 PM -
Need new Hydraulics;Time to Upgrade My Clutch?
By eldrijt in forum Manual TransmissionReplies: 0Last Post: 07-28-2007, 04:48 PM
