Results 1 to 3 of 3
02-28-2008, 05:48 AM #1Junior Member
- Sep 2006
- Norwalk, CT
Torrid Red- 2005 GTO
Tighter stall with higher viscosity ATF?
Has anyone tightened up their converter by using a higher viscosity ATF? I have a 3000-rpm converter that is not as tight (efficient) as I would like. When the trans and ATF are cold, the converter is tighter due to the higher viscosity of the ATF, but when the trans gets up to normal operating temperature (yes, I have a trans cooler), it is looser than I like. I also occasionally get a P0700 code because the converter is slipping a little too much. I'm very happy with the converter otherwise. Thanks for your help.
02-29-2008, 12:53 PM #2Dana
- Jun 2006
- Calimesa, California
Go with Lubrication Engineers Monolec 7500 www.le-inc.com/. It is slightly thicker than Dexron III. It offers better lubrication, runs cooler, does not aerate easily, does not thin out as easily. This is one way of reducing the stall a little, especially if you are happy with it being a little tighter.
03-01-2008, 06:22 AM #3Junior Member
- Sep 2006
- Norwalk, CT
Thanks for the information. Do you happen to know where I could buy Monolec? I have also been considering Red Line Synthetic High-Temperature ATF. That has a higher viscosity then regular ATF. Do you have any experience with the Red Line ATF?
SuperCharged Silverado Oil Viscosity
By Sarge in forum General HelpReplies: 20Last Post: 07-01-2009, 06:28 AM -
using tighter stall and have a p1870 code?
By Frankthetank in forum Automatic TransmissionReplies: 7Last Post: 08-25-2008, 12:47 PM -
lower tire press. higher ET, higher press lower ET???
By greatwhiteZ28 in forum Drag RacingReplies: 1Last Post: 10-20-2007, 05:57 PM -
whats the benifit of a higher stall and....
By showtimesteele99SS in forum Automatic TransmissionReplies: 8Last Post: 07-06-2007, 10:06 AM -
How does the stall converter behave, does the car move below stall speed?
By 99bluebird in forum Automatic TransmissionReplies: 15Last Post: 07-02-2007, 01:49 PM
