Thread: My Story!!!!
    Junior Member Badass99SS's Avatar
    Washington
    99 Camaro ss
    My Story!!!!
    Well I started to tear my car apart in January. I have to work full time and go to school full time as well, needless to say not much time to work on it. My goal for the winter was to do a head and cam swap along with a procharger. Parts I ended up installing are listed below. In the past I have built several small blocks and a 496 stroker for my 69 Chevelle.
    The car was easy to tear apart, I think the most difficult task for me was getting the radiator out and the harmonic balancer bolt out. For some reason the motor wouldn't lock up in ANY gear 1st,2nd,3rd,4th,5th,6th....nothing. Ended up runing a chain threw the balancer and around the sway bar, worked like a charm. As far as getting the oil pump off, dropping the pan a couple inches helped me tremendously. Before I pulled the cam out I made sure I had it dot to dot, after I installed the cam the sprocket and timing chain went on first try dot to dot.
    Throwing the motor back together was a breeze, just took my time and double checked everything. For most of the head and cam install I was using LS1howto.com, that write up is very good. The only beef I had with it was the instructions on installing the rockers, they state throw them on and torque them down. For me I followed the GM pattern, find TDC torque valves/rockers blah blah blah turn 360 torque valves/rockers blah blah. Procharger install was a breeze, took some time to run the intercooler piping. I used the trap door method for the fuel pump, had second thoughts about it but glad I did in the long run.
    Went to start the car today and it fired right up, idle is still a little sketchy. As of now I still have open headers but it will be at the exhaust shop ASAP for my custom true duals over the axle. After I get that done it's on the trailer to the dyno to get a good tune. I will have a vid up as soon as possible, for now enjoy the pics.
    FAST 90 intake
    PTM 90 throttle body
    Mototron 60# injectors
    Patriot LQ9 heads
    EPP blower cam
    COMP pushrods
    JP timing chain
    Melling HV oil pump
    ATI balancer
    Walbro intanke fuel pump
    Fuel pump hotwire kit
    Hooker LT
    ARP head and balancer bolts
    Procharger P-1sc 8 rib kit
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    Nice man, how much hp are you expecting to lay down with your setup?
    Senior Member Street Lethal's Avatar
    New Jersey
    Nice build, good luck with her....
    Washington
    99 Camaro ss
    Quote Originally Posted by Johns00Z28 View Post
    Hoping between 550-620RWHP depending on the dyno. I heard mustang chassis dyno's are usually a little lower than others.
  1. What's the story on LS1.com R3?
    By mitchntx in forum Almost Anything Goes
    Last Post: 02-18-2010, 12:26 PM
  2. OK this is the story
    By Sarge in forum Almost Anything Goes
    Last Post: 10-13-2009, 03:18 AM
  3. Your BEST Get Away Story!
    By 7camaro7 in forum Kill Stories
    Last Post: 06-22-2008, 08:58 PM
  4. Sad story
    By DrMilhouse in forum Almost Anything Goes
    Last Post: 06-22-2006, 01:31 PM
  5. BS story?
    By SeVeReDiStOrTiOn in forum Almost Anything Goes
    Last Post: 03-06-2006, 08:11 PM
