    Member eatsrice's Avatar
    palatine
    2001 formula firebird
    what is causing this to happen?????
    so my driver side window is very slow and when you are lowering the window and it gets about half way down it kind of falls a little then it starts lowering under its own power again very slowly. when you are raising the window it is very slow and once it is up as far as it will got it is still not up all the way. there is like an inch gap at the top because the window won't go up all the way. what is causing this. is it the motor the regulator the track what is it. please reply with sny knowledge you have because I hope to get it fixed tomorrow. THANKS
    Aug 2006
    Missouri
    94 Camaro Z28
    I don't know much about the window tract, but it sounds like whatever is supporting the window is sagging. Maybe its worn out. But you definately need a new window motor, before it completely goes out on you.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    the motor... read around, your not the only one with this problem bro.
    Member Stricken1's Avatar
    Florida
    2001 Trans Am WS6
    The gears in the motor are stripping out...you need to replace the motor.
  1. Help: What is causing this?
    By kenro23 in forum General Help
    Last Post: 11-22-2011, 09:37 PM
  2. could the pcv valve be causing this?
    By 4thGenTA in forum General Help
    Last Post: 09-13-2010, 12:28 PM
  3. Help: Anyone know what is causing this?
    By Arrison24 in forum General Help
    Last Post: 09-03-2010, 05:14 PM
  4. Question: what could be causing this code?
    By 02silverbird in forum General Help
    Last Post: 07-06-2010, 05:06 AM
  5. Question: what would be causing my headlight to do this?
    By dbrichrider33333 in forum Firebird / WS6
    Last Post: 05-26-2010, 11:02 PM
