Results 1 to 3 of 3
    Fort Worth, Tx
    2002 Camaro Z28
    Something is terribly wrong with my car.
    my car was setting off the ses light for multiple misfire on multiple cylinders, and primary ignition coil 'e', so i took it to a friends shop, ran the scanner, it showed cyl 2 and 7 with a lot of misfires, so he swapped the coil off of on of them and then the misfire moved to 4 and 5. he changed out the plugs with factory replacements, the miss wasnt as noticable. it usually missed after sitting on a cold night, but got a lil worse. i took it home, drove it, and now it is bad, missin like crazy, really rough idle around 350, ses light goes off like crazy, just straigh up somethin bad, please help. the starter sounded like it is going out, grinding. any help would be great. the sooner the better.
    Bragg NC
    Met. Sunset Orange
    01 SS
    If he moved the coils and the miss fire's followed then it sounds like your coils are shot.
    J
    Fort Worth, Tx
    2002 Camaro Z28
    im not sure if the misfire followed the coils, but i took it up to autozone today and it read open injector circuit, o2 sensor heater circuit somethin, multi. misfire on multi. cyl., primary ignition coil 'e'. the multi misfire and ignition coil 3 i had before he moved the coils, so i dont think its the coils. possible a wiring problem. i think the positive from the battery to my subs might have messed up my pcm harness. dunnkno.
  1. 'New motor - bogs terribly off idle, undriveable
    By 388bu in forum Computer & Tuning
    Last Post: 06-19-2010, 01:08 PM
  2. What could be wrong?
    By 2500HD4X4 in forum V6
    Last Post: 06-02-2010, 12:34 PM
  3. Wrong Place Wrong Time
    By Fearls1 in forum Firebird / WS6
    Last Post: 05-07-2010, 06:26 AM
  4. something is terribly wrong with my car
    By kidA(somedayullnoit) in forum Computer & Tuning
    Last Post: 02-18-2008, 05:15 PM
  5. Something Is Terribly Wrong!! Help!!!
    By tmtyj5.7 in forum Manual Transmission
    Last Post: 05-14-2006, 01:11 AM
