    Trevose
    1999trans am ram air
    Something Is Terribly Wrong!! Help!!!
    First off, I pull up to the line and blew away a mustang, by atleast 5 lanes. Then I returned to race a hatchback civic and gave that stupid M*** F**** three cars. Then I take off, first gear, second gear and I was killing 'em, then I went to third gear and let the clutch out and it only came out half way and grinded third gear. After that something was burning and it wasnt the car I raced, it was mine!!! Ever since, when I shift hard (racing) it grinds!!! What is this? What can I do? What needs to be done? Please help, this is my baby and she is sick!!!
    Feb 2006
    2002 WS6
    My best uneducated guess is that you clutch decided that it would be a good time to take a permanant vaction.
    Coatesville Pa
    Blue
    2001 Pontiac Trans Am
    Your hydrolics need updated. Well the slave cyclinder anyway.
    Lincolnton, NC
    02 Camaro SS
    Synchronizers and shift fork. They came out w/ updated shift forks from aluminum to steel. Also there is an article about the clutch master cyl. return line being downsized and not replenishing the cmc fast enough. By the time you get to third you have no fluid pressure and shifting w/o a clutch. There is a fix to drill out the line. Shifting w/o the clutch will cause you to bend the shift forks and break the synchronizers or round off the synch. rings. Hope that helps.
    Junior Member Cocheese's Avatar
    Stockton, CA
    1999 SS
    I belive that free mod is called the "Drill Mod" or something along those lines. From what i hear it works great. I think there was something mentioned in a recent GMHTP about that.
    Every day is a gift-enjoy preston1980's Avatar
    Missouri
    Torch Red
    1999 Corvette Hardtop
    My 99 TA did the same thing.
    It was a master cylinder and or slave cylinder.
    I also did the drill mod (drilled out the line restriction, so fluid returns quickly to the master cylinder when shifting gears rapidly) but not sure if it was needed with the new parts.
    Either way I did a spec 3+ clutch and Im very happy
    You need the updated master and slave cylinder from GM, and now probally a new clutch, judging by the clutch burning smell and the carbon (clutch disk material) build up on your pressure plate and clutch disk are keeping your tranny turnny slightly when your clutch is pushed to the floor. Thats why you are having probs going in and out of gear, grinding as you call it. You are not fully disengaging.
    Or maybe you could have it cleaned up and reinstalled, but if you already got it out, I say new clutch. How about a Spec brand, they rock!!
  1. 'New motor - bogs terribly off idle, undriveable
    By 388bu in forum Computer & Tuning
    Last Post: 06-19-2010, 01:08 PM
  2. What could be wrong?
    By 2500HD4X4 in forum V6
    Last Post: 06-02-2010, 12:34 PM
  3. Wrong Place Wrong Time
    By Fearls1 in forum Firebird / WS6
    Last Post: 05-07-2010, 06:26 AM
  4. something is terribly wrong with my car
    By kidA(somedayullnoit) in forum Computer & Tuning
    Last Post: 02-18-2008, 05:15 PM
  5. Something is terribly wrong with my car.
    By kidA(somedayullnoit) in forum General Help
    Last Post: 02-18-2008, 08:21 AM
