Results 1 to 20 of 22
Thread: sail speakers
    Junior Member griftymcgrift's Avatar
    New Jersey
    medium blue metallic
    99 Trans Am
    sail speakers
    My sail speakers blew and i put rockford fosgate 6 1/2 components ( with the tweeter in the middle)in and they have very little sound now. i know its the ohms. is there any way to reduce the ohms of the speaker or increase the ohm capability of the radio? i was thinking about cutting the tweeter wire b/c i know that is the reason for some of the extra ohms....any help guys?
    thanks
    maine
    2002 z-28
    i woluld take back the coaxils...and get a pair of mid bass speakers that will work......plenty of info on speakers that fit and will work.....IMO you will not be happy with those speakers if you do what your planning to do......
    Member CJREX's Avatar
    GA
    Gone:2001 Camaro SS #4846
    Elemental Designs 7Kv2 FTW.
    New Jersey
    99 Trans Am
    the EDs sound like what im gonna get....thay have GREAT reviews...do any stores supply them or is it internet only?
    GA
    You can very rarely find them on eBay.
    Best to just get them from ED website.
    The listed price includes shipping so it's pretty reasonable.
    Around $65 each.
    Chicagoland/Champaign
    '97 Z28 M6
    When they are on eBay, they're usually being sold by Elemental Designs anyway for about the same price... just a way for them to reach out to more people.
    G.M. SERVICE MANAGER LS16SPD's Avatar
    virginia
    navy blue metallic
    2000 z28 camaro
    Just Do Away With Everything Like I Did Put Some Infinitys In The Doors And Rear Panels 400 Watt Amp And A Small Sub Its Un Fuckin Real!!!
    4.10 RICHMOND GEARS,LAKEWOOD LCA'S,EATON POSI,EDELBROCK TORQUE ARM,
    LAKEWOOD PANHARD BAR,SLP LID,,B&M RIPPER SHIFTER,EDELBROCK STRUT TOWER BRACE,SLP FAN CONTROL,SLP LINE LOCK,17 INCH ZR1S WITH 315 35S AND 275 40S,SLP Y-PIPE,TSP 224/224 112LSA CAM,COMP SPRINGS,TUNED BY FROST @ LSXTUNE.COM
    New Jersey
    99 Trans Am
    sooo the elementals, i can just plug and play?...i know i need the ones w/ two inputs, but otherwise..just plug em in? i dont need a lot of sound... just to listen to a lil loud...haha.
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Yeah.. I'm in the same boat.. mine have finally gone.. I dont want to stick a lot of money into them.. but want something that sounds good.. cause my EQ looks like a set of stairs... lol
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    '97 Z28 M6
    Quote Originally Posted by griftymcgrift View Post
    No -- you need a spacer.
    http://ls1tech.com/forums/showthread.php?t=639901
    st.louis
    kicker has new subs that will fit in the sail panel. its the kicker cvt65. looks really good and shallow enough that you wont need to put a spacer in.
    Quote Originally Posted by blacklightning01 View Post
    per kicker's website-they recommend a sealed enclosure for better responce. the ED's are free-air speakers and would still be a better choice.
    Good looking out though! I was about to consider them
    virginia
    navy blue metallic
    2000 z28 camaro
    Check Out The Bostin Acoustics Stuff
    '97 Z28 M6
    Quote Originally Posted by LS16SPD View Post
    He's looking for sail panel replacements... Boston Acoustics only offers subs as small as 8"
    '97 Z28 M6
    Though Kicker doesn't state it specifically, I'm sure they would be fine free-air. Below are descriptions I found off of two seperate sites regarding the product:
    "Kicker CompVT 6.5" subwoofer was specially designed for “Livin’ Loud” in the harsh automotive environment. CompVT subwoofers are versatile and surpass the competition in a sealed box, but can also be mounted in free air applications and factory cutout locations. The small diameter of the CompVT 6.5" subwoofer makes it ideal for custom installations and space-limited applications."
    Details:
    * 6.5" 4-ohm subwoofer
    * injection-molded polypropylene woofer cone with ribbed Santoprene surround
    * suitable for marine use
    * works in free-air applications
    * power handling: 50-150 watts RMS (300 watts peak power)
    * frequency response: 25-350 Hz
    * sensitivity: 84.6 dB
    * top-mount depth: 2-13/16"
    * sealed box volume: 0.2-3.0 cubic feet
    * warranty: 1 year
    Junior Rocketeer jimmi7769's Avatar
    Russiaville, Indiana, United S
    Sunset Orange
    2001 Z28
    doesn't that 6.5" 4 ohm speaker line make it not to good for the 2 ohm monsoon setup??
    '97 Z28 M6
    Quote Originally Posted by jimmi7769 View Post
    They make a 2 ohm version..that's just the one I happened to copy.
    And 4 ohms would be fine anyway (but since there is a choice here, 2 ohms would be best)... the higher quality speaker and better sensitivity would make up for the difference.
    New Jersey
    99 Trans Am
    my sail speakers have two sets of onputs. and on the back it says 4ohm/4ohm. i notice the kickers only have one set of inputs...whats up w/ that?
    '97 Z28 M6
    Firebirds use dual voice coil subs.
    You would just use one pair of wires to power a single voice-coil sub. You lose some power from the Monsoon amp though. Because of that, I think the best replacement for the Firebirds are these: http://ls1tech.com/forums/showthread.php?t=639901
    Unless someone can find another 6.5" dual 4-ohm sub...
    Jan 2008
    Jonesville NC
    1999 Camaro SS M6
    Does anyone know if you have to cut or drill anything to put those kicker subs in the sail panels? If not I am getting a set for my camaro.
  1. Sail Panel Speakers
    By idle in forum Stereo and Electronics
    Last Post: 08-03-2011, 05:29 PM
  2. Question: Sail speakers and rear speakers
    By TJKIDD in forum Stereo and Electronics
    Last Post: 06-01-2011, 04:21 PM
  3. WTB: Sail Speakers/Subs
    By doctorleevil in forum Parts Wanted / Trade
    Last Post: 10-09-2007, 01:35 PM
  4. Sub issue/ new sail speakers
    By Blk00ws6 in forum Stereo and Electronics
    Last Post: 04-10-2007, 05:08 AM
  5. what sail panel speakers should i buy???
    By TransAmBeast08 in forum Stereo and Electronics
    Last Post: 07-01-2006, 01:10 AM
