    Junior Member TJKIDD's Avatar
    Mar 2011
    San Antonio,tx
    1999 camaro z28
    Sail speakers and rear speakers
    Yeah i'm having a hard time trying to find out whats a direct fit for my sail speakers and rear speakers. I have a 99 camaro. I already have infinity speakers in my door panels and a blaupunkt amp and sub.
    Orlando, FL
    Mean Black
    Quote Originally Posted by TJKIDD View Post
    the rear seat panels are 6 3/4" speakers. the back panels are a 4" speaker with a small tweater by it. The 4" speakers have rivets on them. You need to drill these out to remove the speaker. you will need bolts and nuts or new rivets for the 4" speaker instalation.
    Mar 2011
    San Antonio,tx
    1999 camaro z28
    Ok but do you know what brand of speakers is a good a direct fit? And the back panels are 4" speakers i thonght they were the same size as the sail speakers?
    Orlando, FL
    Mean Black
    Well as far as brands I used pioneer, kenwood and JL in my cars. In my TA i have all speakers pioneer, my sub is a JL and my receiver is kenwood.
    Now are you refering to the back panels as the ones by the rear seats? if you are then yes they are the same size as the front's.
    The ones in the trunk area(the small removable plastic pieces on each side) are 4".
    Member jrzdude's Avatar
    Feb 2011
    Phoenix, AZ
    2002 Black WS6
    I thought the door and rear seat speakers were 6 1/2" ??
    They are 6.5" and the sails are subs
    You're not going to find a 'good' direct fit with popular brands. At least not for the subs or fronts speakers. Fronts have 2 sets of wires going to them. One set is for Low/mid only and the other is for highs only. you have to seperate them.. I went ahead and had tweeter pods put on the top of my doors and that took care of that issue.
    For our Camaros...
    2 ohm mids and subs and 4 ohm tweeters mounted coaxially in the door. 4 ohm in the hatch. Oh, and wanted to add that 4 ohm for the doors is fine. But, the mids are powered off the amp at 2 ohm and the tweeters off the HU at 4 ohm.
    As far as speaker sizes they are as follows:
    Front door-5 1/2 to 6 1/2 Need adapter rings with most speakers but some do not. 6 ½ fit better.
    Sail panel- 5 1/2 to 6 1/2 with adapter ring again some 6 1/2's will fit without.
    Hatch area- 4" and yes, they can be a pain to get out
    Orlando, FL
    Mean Black
    You guys are right. They are 6 1/2. That's what I have in mine.
  1. Sail Panel Speakers
    By idle in forum Stereo and Electronics
    Last Post: 08-03-2011, 05:29 PM
  2. sail speakers
    By griftymcgrift in forum Stereo and Electronics
    Last Post: 04-29-2008, 06:36 PM
  3. Sub issue/ new sail speakers
    By Blk00ws6 in forum Stereo and Electronics
    Last Post: 04-10-2007, 05:08 AM
  4. what sail panel speakers should i buy???
    By TransAmBeast08 in forum Stereo and Electronics
    Last Post: 07-01-2006, 01:10 AM
  5. 99 SS Vert Rear Sail Panel Speakers
    By 2tall in forum Stereo and Electronics
    Last Post: 04-23-2006, 11:21 PM
