    Junior Member dj_phaedrus's Avatar
    San Diego, CA
    1998 Camaro Z28 Convertib
    Convertible top motor
    Hello All,
    I have a '98 Z28 convertible and the top motor needs to be replaced. I can't find any information online or in the Haynes manual that shows how to do this - or if it is something I should attempt to do in my garage. Anyone have experience doing this or know of any how-to info out there?
    Thanks!
    Member LS1Z28's Avatar
    Lake Elsinore,CA
    Camaro
    Have you purchased the new motor yet? They run about $1200.00 from GM.Alls you have to do is disconnect the lines from the old pump and reconnect them to the new one. Just make sure you reconnect them to correct place. Use Mineral oil only when you refill it.You can get it at any pharmacy or supermarket. Fill it to the top line and run the top up and down a couple of times than top off the level and you are done. Don't fill it above the top lline.
    San Diego, CA
    Thanks for the info! Is it is easy to get at the pump or do I have to rip the trunk apart?
    No I have not bought the pump yet. 1200, wow. I was quoted 700 for parts and labor from a local garage.
    Lake Elsinore,CA
    Camaro
    Like I told you in the PM I can do it for 300.00 parts and labor.
  1. convertible Motor
    By JayMoung in forum Convertible
    Last Post: 06-28-2016, 04:09 PM
  2. Help: convertible top motor
    By tripps in forum Convertible
    Last Post: 03-19-2012, 03:17 PM
  3. Convertible Oil for the motor pump
    By sergiomarruffo in forum Convertible
    Last Post: 04-24-2008, 05:58 AM
  4. Replies: 20
    Last Post: 08-24-2007, 05:57 PM
  5. convertible motor
    By yodabill in forum Convertible
    Last Post: 06-19-2007, 06:02 PM
